I have been experimenting with solar hot water heating panels and have had great success but I still want to put some more science behind what I am doing. The type of panel I am using has a black polypropylene felt mat through which I gravity feed water. Laying in contact to this is a layer of Mylar (7 mil). Above this is a polycarbonate glazing that essentially just shields the mylar layer from wind cooling effects. The Mylar prevents water vapor from collecting on the underside of the polycarbonate layer and causing condensation, thus reducing light transmission. The theory is that the solar energy hits the black matt (which acts like a blackbody radiator) which is soaked with water and the water carries the heat away.
My questions: I understand that when the solar energy transmits thru the polycarbonate, the wavelenghts change and the energy is trapped just like the proverbial greenhouse effect.
1) does this mean the wavelengths are too long to now transmit thru the second layer (mylar).
2) If it does transmit, how much does?
3) Is it more likely the heat transfer is really by convection, and the black felt is not really acting like a blackbody radiator?
4) Does it matter if I change the thickness of the poycarbonate or Mylar? (will more or less light transmit?)
5) Does the condensation on the inside of the polycarbonate really reduce the solar energy transmission? (yes it reduces light transmission but I am after the energy, not the light!)
