Previous in Forum: Aligning a Single-Bearing Alternator and Engine   Next in Forum: Pneumatic and Mechanical Clamping Cylinders
Size Weld on Skirt Basering / Open Half-Skirt Basering Vessel
11/19/2008 11:03 PM
Dear Members,
i have one vessel with full skirt and one more with open half skirt to be weld on the platform at elevation + 33500, with wind pressure 88.8650kgs/m2 and weight around 5700kg. Anybody have an idea to calculate the weld size at the basering for these 2 vessel and appreciated if someone can send a softcopy(Excel file) or whatever to study.
Thank you.
Re: Size weld on skirt basering/open half skirt basering Vessel
11/20/2008 7:18 AM
I'd be glad to help you, but to accomplish it I'd like first to see a drawing with vessels and platform geometry, and also the required weld position and support elements. It will depend not only the loads, but also weld position and base metal. I can help you to find a good start based on AISC and AWS specifications, but post some sketch or send me an email with it so I can give you an idea of what will be.
HOWEVER - CAUTION:
Well, in advance, you'll need to observe at least one of the following specs, depending on your installation country: AISC, AWS D1.1, ASME Sec. III and sec. IX.
Watch out. It is not so simple as it may seem. Certified people for design and construction is required.
Humm... suspicious you are...
11/21/2008 7:31 PM
Dear Sir,
Could you provide your email to me because i dont know how to attached a file in this forum.
Thank you.
Register to Reply 2 comments
