Previous in Forum: Can Anyone Identify This Steel?   Next in Forum: mechanical engineering fabrication proects
18 comments
AHU capacity
11/21/2008 11:22 PM
hi everybody!
has anybody know how to determine the required AHU cooling capacity in a room.?
I want to know what is the guidlines to design/install the air cond system in our packaging room?
thanks & regards
syachah
Good Answers: 19
Re: AHU capacity
11/21/2008 11:40 PM
Hire an air conditioning Consultant or sit down with one to help you out. It's engineering and not rule of the thumb.
Re: AHU capacity
11/21/2008 11:53 PM
dear ducon
Definitely i'll discuss with them, I only need some information with you all before i go further with them.i have to source it in many ways not only depend on the consultant? am i right?how you going to discuss with other people which have better knowledge than you.
syachah
Good Answers: 19
Re: AHU capacity
11/22/2008 11:46 PM
I totally agree with you but take it like this - a person going for a complex surgery requirement. Now how much knowledge does he need to talk with a Surgeon. Obvious with all his test reports(data) he trys 2-3 Surgeons and finds out about reputation from friends/ friend's friends before he decides.
Yours too, is a complex system involving engineering, so you have to go with your data of room size, amb. temperature, required temp. etc. to an HVAC Consultant to first advice you what other data more is required. You then take the missing data and he/others discusses with you on your system highlighting requirement of chiller/AHUs/ ducting etc. etc. etc.
You then try the next one & the next. Makeing your decision since now you are aware.
Now if you think you can design it - best of luck or, hire the HVAC Consultant think best. No hard feelings about this.
Re: AHU capacity
09/29/2010 10:54 PM
THanks Ducon and everybody..your comments are highly appreciated...i never hard feeling about this :)...
Re: AHU capacity
04/19/2020 5:02 AM
Mr. ducon,
You are great,
the last line in your reply which reads as " Now if you think you can design it - best of luck or, hire the HVAC Consultant think best. No hard feelings about this."
DHAYANANDHAN.S
DHAYANANDHAN.S
Re: AHU capacity
11/23/2008 1:30 AM
hi the capacity of the AHU ( air handling unit) unit is worked out in cubic feet of cubic meter.
e.g. if lenth of room is 20feet. width is 20 feet and is 12 feet high. then the
cubic capacity =20x20x12=4800 cft.
as u need AHU for packaging area. consider 1 ton capacity for 1000 cft
so the tonnage required is 5ton
Ravinder K. Bawa
Re: AHU capacity
10/09/2009 8:13 AM
Hi there!
May I ask if when can I apply the computation that you gave? Does it apply in genereal estimation of AHU?.
Thank you very much!
Re: AHU capacity
09/29/2010 11:01 PM
egan jade
yes ,general estimation to determine the AHU cooling capacity..we need to know the room volume in order to determine the required AHU air flow design and room air change as well.
thanks,.
Re: AHU capacity
11/23/2008 4:20 AM
Hi Ducon and syachah,
You guys both have valid points, we're all members must help each other. maybe we just misinterpret each other. be patient. I do beleived that this is not a group of forum to criticize each other, I agree with Ducon better to hire the consultant, however syachah also want to know before dealing with the contractor or consultant to give him little idea and guide how the contractor come up with the proposal, "if you don't know you ask" not to pretend you know everything and then later found you're stupid in doing wrong things by your own. on your side syachah, you better have tell that in the beginning so we know how we supposed to help, keep calm guys
my contribution base on my knowledge.
W x L x H multiply by 50 or 60 then that the total Btu you can fit.
10' x 20' x 9' x 50 = 90,000 Btu capacity you can fit. or
10' x 20' x 9' x 60 = 108,00 Btu capacity or nearest Btu capacity available you can fit. this are the calculation I apply if i want to put air-con in the room.
reason why the multiplier is not fixed in simple reason that depending on the place of application, like packaging room need not to be same maintaining room temperature with the Hospital ICCU. consider also the room location if it is in the middle of the dessert or in the middle of building structure where heat load is not too excessive. Hope will help you to have small idea on my small knowledge in air-conditioning calculation.
Kind regards
Roman
Good Answers: 19
Re: AHU capacity
11/23/2008 1:16 PM
Thanks & i agree. syachah, I' m sorry.
Thanks for teaching me too 'cause i'm a heating guy.
OK now here we get A/C Split Unit 1.5 T = 18000 Btu. & 1 T = 12000 Btu
So
90000 Btu/18000 Btu = 5 T = 3 nos A/c split units of 1.5 T+ 1 no 1 T ?
108000 Btu/18000 Btu = 6 T = 4 nos A/c split units of 1.5 T?
Is this correct ?
Re: AHU capacity
11/24/2008 12:57 AM
Hi ducon, great!!! on my calculation you are 100% right, now syachah at least have an idea and deal with the contractor on the capacity required. now duco how nice you feel we both help syachah on his question. keep it up being patient and keep helping others someday somehow me too i need your input, if you can have a look on yesterday forum I posted tha "wind turbine generator" at least a lot of our member contributed and I gained from that info. well done!!!
kind regards
Roman
Good Answers: 19
Re: AHU capacity
11/24/2008 1:12 AM
Thanks buddy you brightened my day
Re: AHU capacity
11/24/2008 11:57 PM
dear ducon/roman/bawa/jcchiefeng
i just went back from my leave.Thanks for the good information, its very useful for me.ducon , sorry for that, i dont have any hard feeling on that.
ducon/roman
why you use the WXLXH (m3) to get the capacity .I have told by my consultant to use only m2 ( wxL) to get the capacity .which one is correct?. Is it correct from the room volume we can determine the required air flowrate and air change for the AHU?.
I have checked the internal heat load of the room ( lighting/human/general power/
machine heat load).for the lighting load and general power- how to determine their heat load?.is it power in KW for each equipment multiply with 860 kcal/hr.please confirm.
thanks
Re: AHU capacity
11/25/2008 4:06 AM
Hi Syachah,
He was also right due to different aprroach in calculation base on the below;
Heat Load - the amount of heat generated is know as the heat load. Heat is measured in either British Thermal Units (BTU) or Killowatts (kW). 1 kW is equivalent to 3412BTUs.
The heat load depends on a number of factors, by taking into account those that apply in your circumtances and adding them together a reasonably accurate measure of of the total heat can be calculated.
Factors include:
The floor area of the room
The size and position of the window
The number of room occupants (if any)
The heat generated by equipment
The heat generated by lighting
Floor area
The amount of cooling required depends on the area of the room. to calculate the are in square meter
To get Room Area BTU = Length (m) x Width (m) x 337
Window Size and Position
If your room has no window then you can ignore this part of calculation, how ever as rule of thumb there are window you need to take and orientation into account.
South window BTU = south facing window Lenght (m) x Width (m) x 870
North window BTU= North facing window Lenght (m) x Width x 165
If there no blinds on the window multiply the results by 1.5
Add together all the BTUs for the window
Window(s) BTU = South window(s) BTU + North window (s) BTU
Occupants
You will have to take into account people who normally working in the space. the heat output is around 400 BTU per person.
Total Occupants BTU = Niumber of Accupants x 400
Equipment
Clearly most heat in the roo is generated by the equipment. this is trickier to calculate that you might think. the wattage on equipment is the maximum power consumption rating, the actual power consumed may be less. However it is probably safer to overestimate the wattage than underestimate it.
Equipment BTU = total wattage for all equipment x 3.5
Lighting
Take the total wattage of the lighting and multiply by 4.25
Lighting BTU = Total wattage for all lighting x 4.25
Syachah, hope that the above information will help you on your project.
Take note:
If your monthly energy bills cost you more than $75,000 a month should need my services in making it 15% to 30% lower with zero investment from your side send me your email add and will send you proposal I am starting a new business of Energy Management services. Remember ZERO investment from your company just let me manage your energy without adversely affecting your production or operation.
Kind regards
Roman
Re: AHU capacity
11/25/2008 5:04 AM
Dear Roman
Very good information! thanks a alot.Now , i have confident to further my discussion with my consultant.anyway what is ur email add? i could't find it in this page.
thanks & regards
syachah
Re: AHU capacity
11/25/2008 7:52 AM
Hi syachah,
you can email me here: ceo@megaenercon.com
Re: AHU capacity
11/26/2008 12:13 AM
u r right bro, plz think a little , u want to cool ur room , that means the air in that room have to be cooled and the air is in cubic meter of cubic feet ,,u consider length and width of the room ...
what about hight of the room ,,,,consider two rooms both have same width and length 20 ft by 20 ft. now if one room is 14 feet high and other is 10 feet. than according to ur consultant the capacity of air handing unit will be same . but according to the law one room have capacity=20x20x15= 6000cft. that means 6 ton and the other will have 20x20x10=4000 means 4 ton
consider it
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
Re: AHU capacity
11/23/2008 9:31 AM
Please read below. This is how complicated the engineering of a system becomes when the need to conform to local, district or national codes. I prefer to design according to ASHRAE requirements and then "tweak" as per local building requirements or owner specification. Research the books or documents for content. This is NOT an advertisement to buy these products!
Please forgive the long text, but it seems this thread needed to cover all bases for the original request.
Engineers know all about ASHRAE's involvement with the U.S. Green
Building Council LEED program. But in an effort to assist architects,
program managers, building owners, and others in the use of LEED,
ASHRAE has put together a new package that includes three ASHRAE
standards frequently used in conjunction with LEED v.2.2. In addition,
we include the Standard 62.1 and Standard 90.1 User's Manuals, as well
as three books from the popular ASHRAE Advanced Energy Design
Guide series, making a powerful set of tools for use with LEED.
All of the following publications are referenced in LEED v2.2 and are
available for purchase in this convenient package:
ANSI/ASHRAE/IESNA Standard 90.1-2004, • Energy Standard for
Buildings Except Low-Rise Residential Buildings
(I-P edition)
• 90.1-2004 User's Manual
• ANSI/ASHRAE Standard 62.1-2004,
Ventilation for Acceptable Indoor Air Quality
• 62.1-2004 User's Manual
• ANSI/ASHRAE Standard 55-2004,
Thermal Environmental Conditions for Human Occupancy
• Advanced Energy Design Guide for Small Office Buildings
• Advanced Energy Design Guide for Small Retail Buildings
• Advanced Energy Design Guide for K–12 School Buildings
• Procedures for Commercial Building Energy Audits
ANSI/ASHRAE/IESNA
Standard 90.1-2004
The purpose of this standard is
to provide minimum
requirements for the energy-efficient
design of buildings except
low-rise residential buildings.
This standard provides (a)
minimum energy-efficient requirements
for the design and
construction of 1. new buildings
and their systems, 2. new
portions of buildings and their
systems, and 3. new systems
and equipment in existing
buildings and (b) criteria for
determining compliance with
these requirements.
This manual provides detailed
instruction for the design of
commercial and high-rise
residential buildings to ensure
their compliance with ANSI/
90.1-2004.
In addition, this manual: encourages
the user to apply the
principles of effective energyconserving
design when designing
buildings and building
systems; offers information
on the intent and application
of Standard 90.1; illuminates
the standard through the use of
abundant sample calculations
and examples; streamlines the
process of showing compliance;
provides standard forms
to demonstrate compliance;
and provides useful reference
material to assist designers in
efficiently completing a successful
and complying design.
A CD accompanies this manual
containing supporting files.
ANSI/ASHRAE
Standard 62.1-2004
to specify minimum ventilation
rates and indoor air quality that
will be acceptable to human
occupants and are intended to
minimize the potential for adverse
health effects. This standard
is intended for regulatory
application to new buildings,
additions to existing buildings,
and those changes to existing
buildings that are identified in
the body of the standard. This
standard is intended to be used
to guide the improvement of
indoor air quality in existing
buildings.
This manual used in conjunction
with the Standard 62.1:
• Offers information on the
intent and application of
Standard 62.1
• Explains the standard
through the use of sample
calculations and examples
• Encourages the user to apply
the principles of good
indoor air quality and
effective ventilation when
designing buildings and
building systems
• Provides useful reference
in efficiently completing a
successful and compliant
design
• Gives guidance to building
operation and maintenance
personnel
manual containing the 62MZCalc
spreadsheet that assists in
the Ventilation Rate Procedure
calculations.
PRICES SUBJECT TO CHANGE WITHOUT NOTICE. ORDER AT WWW.ASHRAE.ORG/BOOKSTORE
OR CALL TOLL FREE, 1-800-527-4723 (US/CANADA), OR 404-636-8400 (WORLDWIDE).
$110/$88 (ASHRAE Member)
Softcover; 8.5
× 11 in.; 2004
$93/$74 (ASHRAE Member)
Softcover; 8.5
× 11 in.; 2004
$60/$48 (ASHRAE Member)
Softcover; 8.5
× 11 in.; 2004
$55/$48 (ASHRAE Member)
Softcover; 8.5
× 11 in.; 2005
ANSI/ASHRAE
Standard 55-2004
This standard specifies the
combinations of indoor space
environment and personal factors
that will produce thermal
environmental conditions
acceptable to 80% or more of
the occupants within a space.
The environmental factors addressed
are temperature, thermal
radiation, humidity, and air
speed; the personal factors are
those of activity and clothing.
Advanced Energy
Design Guide for
For developing energy-efficient
buildings, the Advanced Energy
Buildings provides a sensible
approach by including practical
products and readily-available,
"off-the-shelf" technology. The
Guide offers you all the tools
you need to create an energyefficient
building where the
owners will see a 30% energy
savings compared to buildings
that only meet the minimum requirements
of ANSI/ASHRAE/
IESNA Standard 90.1-1999.
Advanced Energy
Design Guide for
The Advanced Energy Design
is the second in a series
designed to provide recommendations
for achieving
30% energy savings over the
minimum code requirements
of ANSI/ASHRAE/IESNA
Standard 90.1-1999.
This Guide focuses on small
retail buildings, which make
up the bulk of the retail space
in the US. These buildings use
unitary heating and air-conditioning
equipment and are
limited to 20,000 ft2 in size.
Advanced Energy
Design Guide for
Energy costs typically account
for 16% of a district's "controllable"
costs. The Advanced
School Buildings will help your
facilities staff design new construction,
renovations, remodeling,
and modernization projects
that use substantially less
energy—at least 30% less—
than those built to minimum
energy code requirements.
Achieving this 30% target is
not only possible, but easy, and
the Guide includes case studies
that show schools around the
country that have achieved or
exceeded the target.
$47/$39 (ASHRAE Member)
Softcover; 8.5
× 11 in.; 2004
$62/$49 (ASHRAE Member)
Softcover; 8.5
× 11 in.; 2004
Softcover; 8.5
× 11 in.; 2006 $62/$49 (ASHRAE Member)
Softcover; 8.5
× 11 in.; 2008
Procedures for Commercial Building Audits
This reference defines good procedures for an energy survey and analysis for purchasers and
providers of energy audit services. Also included is a format for buildings and their energy use that
allows data to be shared in meaningful ways.
The included CD provides more than 25 guideline forms (in both PDF and Word formats) with
explanatory material, to illustrate the content and arrangement of a complete, effective energy analysis report.
$58/$39 (ASHRAE Member); Softcover; 8.5
× 11 in.; 2004
"Memorize the calculations, you look like a fool searching your notes while teaching class"
Register to Reply 18 comments
Anonymous Poster (1); bawa333us (1); dhayanandhan.s (1); ducon (4); Egan Jed (1); jcchiefeng (1); Roman (4); syachah (5)
