Previous in Forum: noise control   Next in Forum: IEEE Designations for Annunciator Panels
Diesel Fuel and Galvanized Steel Pipes
11/24/2008 5:01 AM
Dear Friends ,does diesel stored in galvanised steel threaded pipes have any chemical recation??
Ing.Joe Grech
Good Answers: 101
Re: Diesel
11/24/2008 2:16 PM
Yes, Diesel has a chemical reaction with galvanized steel. Never use Galvanized steel with any diesel/biodiesel/petrol.
Re: Diesel
11/25/2008 3:29 AM
many thanks
Ing.Joe Grech
Re: Diesel
11/25/2008 3:23 PM
Interesting!
We have an supplier wich delivers us galvanised 1000Liter Diesel storage tanks and insured us nothing could happen.
In the Dutch Dragon machinery which we build in the Netherlands stainless steel tanks are used, as John Deere has advised us to either plastics, Stainless steel, Steel with a proper coating or aluminum.
What could happen with the fuel in the galvanised tank and where can I find more information.
Thanks!
Good Answers: 101
Re: Diesel
11/25/2008 3:49 PM
Do not store diesel fuel in galvanized containers because the fuel may dissolve the zinc coating, which can then remain in solution until deposited in the pump or injectors. It is the sulfer in the fuel which attacks the Zinc in the galvanized steel. I would suspect the tank supplier which uses galvanized tanks must put some kind of coating on the inside of the tank such as aluminum. The galvanization is most likely used primarily for the outside of the tank, to protect against environemtal conditions.
Re: Diesel
11/24/2008 4:29 PM
Agreed Never use Galv pipe for fuel us black steel for above ground pipework. underground should always be dual wall Durapipe which is available world wide. Just google durapipe.
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
Re: Diesel
11/25/2008 3:30 AM
Many thanks
Ing.Joe Grech
Register to Reply 6 comments
coconutpete (1); Harmen Beskers (1); jgrech (2); RVZ717 (2)
