Can someone explain how certain high-voltage cables are separated by large distances, and mounted to ceramic insulation bushings, then these same cables are spliced into a multi-conductor jacketed cable with a shield to be taken underground? It is puzzling to me that there is a deliberate effort to keep these cables separated because of the high potential between these conductors, only to have them sit within less than 1-inch separation when they are taken into the underground jacketed cable. If anyone can point me to a source which explains this and other high-voltage design, that would be greatly appreciated.
