Previous in Forum: Deflection of square steel tubing   Next in Forum: saturated steam
fire line of shopping mall
11/28/2008 1:50 AM
hi folks
maximun how many sprinklers we can provide in fire lines of 150mm dia MS pipe, testing pressure is 14 Kg/Sq.cm.
Good Answers: 101
Re: fire line of shopping mall
11/28/2008 2:39 AM
That will depend upon your local building and fire protection codes.
11/29/2008 4:49 AM
One would hope that you are not installing a sprinkler system in a building or complex anywhere near where I live or are likely to go into.
This is covered in building and fire safety codes......and before a premises is opened it would be inspected by fire safety officers.
If you don't know.............leave it to the experts.
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
11/29/2008 6:02 PM
Hi, Guest!
If you can get your hands on a copy of your local building code, there will be a section that answers your question.
Where do you intend to provide the sprinkler system (country, city)? Maybe there is no local building code?
Mark
DVader1000 (1); MarkTheHandyman (1); MOBI (1)
