Previous in Forum: 4 bit alu design   Next in Forum: Wi-Fi Woes
Mac disk space problem
11/30/2008 3:08 AM
I upgraded my Mac OS v.10.4.9 to Leopard in May and after Leopard was installed I had about 13 GB HD space left. It was lightning quick too. The new OS was v.10.5.1
Since then I've been downloading regular Security updates as they prompted till the OS reached 10.5.5 but it was gradually getting slower so I figured I would re-install Leopard and take it back to 10.5.1 to see if it was back to the high speed when I originally installed Leopard.
After I re-installed Leopard last week and it was back to 10.5.1 it went back to running superfast again but yesterday I started getting a notice that said I was running low on Startup disk space and I needed to delete some stuff to gain space.
When I checked available space I have less than 1 GB, about 300MB.
It seems that by re-installing Leopard it has been written adjacent to the 10.5.5 instead of on top of it, which I thought it would do automatically.
I found a file named 'Previous systems' on the HD and deleted that but it screwed it right up so I had to restore that and now it's back to normal but I've still got less than 1 GB disk space.
Can anyone tell me how to delete my old operating systems (both the 10.5.5 and the 10.4.9 that I presume is still on there, which I originally upgraded to Leopard.)
I'm a conservative user of disk space and I deleted all my photos and only gained about 20 MB of new space so I'm pretty sure the problem is the OS's are written adjacent instead of on top of each other.
Re: Mac disk space problem
12/01/2008 4:57 AM
Hi again, Since I posted the above problem I've been on a Mac forum and got the answer, thanks for letting me post anyway!
12/02/2008 6:54 AM
Same thing happened to me and I figured out the problem. Don't believe the amount of space left that is indicated by the mac. Its a flaw from the manufacturers. For some reason the file system reads the disk wrongly. To fix mine, I bought a new external hard drive, transferred all my personal files or vault you could say. including applications, music , documents, etc to the new external hard drive. (Don't remove the system files, etc). Just go to the finder . on the left you should see your user name icon , if you click on it, you should see all your personalized documentations and applications. That is what you should copy to the external hard drive and then delete totally from your mac and empty the trash of course.
Ok, moving on. After you ve done this, when you try to log in, it wont go through anymore with your normal username as you normally use, because all of your settings have been deleted and all. What you need to do is log in as "root" administrator and create a new account from scratch. After you do this, you ll find that all your drive space will be restored and the mac will read the amount of space you have left properly now and it wont mess up again. Well, mine hasnt so far.
Then you can attach your external harddrive and transfer your files and application settings and all. you should be able to get it back to normal as before with all your settings and all :) I hope this helps
Rexy
