Previous in Forum: advantage of cd404   Next in Forum: NAND Flash Memory by CMOS.
11 comments
Underwater Wireless Alert Help
12/01/2008 10:59 AM
Hi there,
I am a masters student on a design and engineering course, and for my final year project i am trying to design an alert device for scuba divers... the idea is that it will be able to send one of a few preprogrammed messages to a similar device held by another diver.
However, I was wondering if anyone knew anything about how to send a wireless signal underwater! I have looked at acoustic comm, and the various problems inherent in that, but i am also aware that there are dive products out there that already use wireless to communicate. I have not, however, been able to find out how they work.
Any comments would be greatly appreciated.
Thanks,
Joel
Re: Underwater Wireless Alert Help
12/01/2008 12:57 PM
hi there..
there are two ways to develop your device for communication.. one can be using acoustics and the other one can be by light- optical communication!
There are sensor networks using optical wireless communication. They work on the concept called- LIDAR- light detection and ranging. refer to some IEEE papers on that topic.
Another field is acoustics i.e acoustic wireless networking. Sound waves can travel really good amount of distances compared to terrestrially used electro-magnetic waves , however,certain factors like limited bandwidth, specific protocols, refractive paths and multipaths taken by sound waves , low speed of these waves make the process difficult...
try designing your device that can actually minimize these losses...
hope this helped!
all the best.
12/01/2008 3:06 PM
Back in the day I worked on a system called ELF - extremely low frequency radio, broadcasting at about 50Hz. It's only ELF radio that can propagate under water for long distances. For relatively small distances the frequency can go up.
http://www.qsl.net/vk5br/UwaterComms.htm
Ocean Reef systems use ultrasonic sound.
http://www.oceanreefgroup.com/
12/01/2008 6:28 PM
Thank you both for your quick responses!
I will investigate both these avenues tomorrow and see where they lead. If you have any other thoughts or comments please leave more!
I think the range that I am aiming for is no more than 50m, so I am assuming that in terms of underwater networks that is relatively short? potentially meaning i can use some higher frequencies.
once again thanks, and keep em' comin :P
Joel
Good Answers: 15
12/02/2008 5:54 AM
For that distance could you use modulated ultrasound?
Chas
12/02/2008 6:35 AM
Thanks,
That seems like a good idea. Do you think it would still be appropriate if I just want to send an activation signal rather than an audible sound message?
Joel
Good Answers: 54
12/02/2008 8:05 AM
Modulated ultrasonics is used in modern submarines. It's called a Gertrude. It's basically an audio (voice) signal riding on an ultrasonic carrier wave using FM modulation. I think 50 meters is easily achieved if you use an ultrasonic transducer with enough power.
12/02/2008 4:33 PM
Joel, May be of some use, would appreciate a call as I have done some design and functionality for this device already.01268 442147 eves. 07957 817355 .
Will call you back if ness'.
Best Regards.
Lez T.
12/02/2008 4:35 PM
Edit landline phone number
01268 442140.
Lez
12/02/2008 11:14 AM
hi..
the modulation of ultrasound waves is done by modulating it with the ultrasound acoustic modulating frequency using the binary frequency shift keying. you will need a transmitter of course, from where you ll send the signals , these signals must be first encoded and then modulated. these modulated - encoded signal then travel and reach the receiver which must be equipped with decoder and a demodulating device.. the receiver could have a hydrophone and a pre-amplifier to raise the level of your received signal..
12/04/2008 10:16 AM
Thanks for your response,
As technical as it was I think I understand the principle. Are there many products that use this type of system already? I think knowing the size and potential cost of such a set up will certainly help me to start adapting the technology to my current concepts.
Joel
12/08/2008 11:49 AM
What if you Use Cell phones on an appropiate enclosure ?
Best regards ( faraon34@hotmail.com )
Register to Reply 11 comments
Anonymous Poster (4); beatenblood (1); bhankiii (1); capblanc (1); PDEstudent (3); Vulcan (1)
