Previous in Forum: Extrusion: Twin Screw or Single ?   Next in Forum: Avocado Oil Production
11 comments
Filtering toxic fumes from burnt plastic
12/03/2008 4:41 AM
Hi,
can a hepa filter system sufficiently filter out the toxic fumes emitted by burning plastic?
Please advise other methods. tnx
Good Answers: 143
Re: Filtering toxic fumes from burnt plastic
12/03/2008 7:48 AM
NO!
The "P" in HEPA stands for particulate. They're good for dust and pollen; they are not intended for fumes, particularly poisonous ones.
You need a Scott Air-Pak (or equivalent) plus eye protection. You also need the advice of an industrial toxicologist if you are burning plastic.
12/03/2008 10:57 PM
I planning to built my own air scrubber for this purpose. I think the hepa filter is effective but more costly.
Good Answers: 143
12/04/2008 7:31 AM
No, the HEPA filter is not effective. If you are even remotely considering this, at least ask a fireman what they use to go into fires where there are plastics. read about airplane fires. Go to the OSHA website. But, don't breathe that crap, please?
12/04/2008 8:53 AM
I suggest a Donaldson Scrubber. View these products at: www.donaldson.com
Engineering will fit your application.
Regards,
Ron H
Good Answers: 143
12/04/2008 10:29 AM
Now I'm confused. Are you planning to incinerate plastics in something like an industrial furnace or in a cogen plant? If so, you need to talk to some industrial pollution guys; a HEPA filter is OK for an after-filter following a baghouse, but I can't imagine using one as a primary. And, no filter, no precipitator comes close to touching dioxins. The generally correct solutions for plastics are:
minimize use;
recycle when economical;
compact and put in leach-free landfill;
incinerate with a controlled burn and a very high chimney, following the basic rules: NIMBY and BANANA.
12/04/2008 8:00 PM
Many thanks for the inputs..
What I am really trying to do is to cut open a plastic material with the use of a hot rod and not mech'l tools of sorts to avoid vibration. I assumed that the process and the byproducts(fumes) are the same as incinerating plastics. Am I correct?
Again,, many thanks.
Good Answers: 143
12/05/2008 6:24 AM
No. When you incinerate, there's a chimney way up there that disperses the fumes. You really have to look at the type of plastic (those with Cl are real nasty) and the applicable laws (are you exposing workers, the general public?). Some of the fumes from burning plastic are toxic.
Good Answers: 97
12/11/2008 4:06 AM
A very cold rod instead
12/06/2008 2:08 AM
DON'T BURN PLASTICES RECYCLE.
01/30/2009 1:30 AM
Hi
I want to melt plastic in canola oil ( like potato fries) and mold the stuff into different things. Does melted plastic releases any fumes? Does the melting stage release as much fumes as burnt plastic?
Thanks
02/16/2009 11:57 PM
Hi
No one has replied to above memo for one month! Am I doing or saying anything wrong?
Register to Reply 11 comments
Anonymous Poster (1); bwire (1); cryukon55 (2); dadw5boys (1); Dodskie (1); Nelson de Leon (1); TVP45 (4)
