Previous in Forum: transformer rating   Next in Forum: operating principle of eletro magnetic lebel sensor
12 comments
Flywheel-Operated Electric Generator
12/04/2008 3:57 AM
Hi!
Can anyone help me to find a vendor for flywheel operated electric generator unit for 2 KWH
Thank you
Good Answers: 230
Re: Flywheel operated electric generator
12/04/2008 4:15 AM
Hello yigalrr
You do not list your Location or Country - Easy for you to do as Edit in your member Profile, then it auto-updates through all your Topics and Posts, including this one.
<"....2 KWH...."> Perhaps you meant 2kW or 2kVA - please advise further.
<"....electric generator unit...."> - Advise Voltage and frequency you need.
<"....flywheel operated...."> - Advise what you man re "Flywheel operated".
Will this generator be supplying any motors? If so, advise type and kW or HP of the motors.
Reply here with
12/04/2008 5:41 PM
Hi Sparkstation!
Thank you for your reply!
Regarding your questions:
1) 2 KW
2) Mechanical Rotation - of any type like trolley or wind turbine etc.
3)It will supply various types of electric consuming utilities up to a total load of 2 KW.
Thank you!
yigalrr
Good Answers: 62
12/05/2008 9:31 AM
You might try these folks to start
www.pentadyne.com
No endorsement, just the only folks I've run into along these lines.
Emmett
Re: Flywheel-Operated Electric Generator
12/05/2008 9:27 AM
We have several MMG (motor, motor, generator) sets that operate as flywheel operated generators for several seconds following loss of power to both motors. (loose one motor (AC), second takes over, lose second motor (DC), flywheel action carries load for several seconds. These were built my mother GE. We get 2kW from them but for only 7 seconds. Maybe GE can help you out though.
12/06/2008 1:38 AM
12/07/2008 4:43 PM
Hi !
Thank you ! but this is not it ... I am looking for the electric unit / system, the system converting the rotational movment into electric current.
Good Answers: 123
12/08/2008 11:48 AM
Is this what you are looking for? This is from grainger. They also have 50, and 75 HP models.
Power Take-Off Generator, Brushless, 12 Rated kW, kVA Rating 12, 120/240 Voltage Rating, Single Phase, Voltage Regulation +/-5 Percentage, 100/50 Amps @ 120/240V, 25 HP Required, Max Motor Starting HP 7.5, 540 PTO RPM, 1.0 Power Factor, Volt/Frequency Meter Type, Length 29 In, Width 10 4/5 In, Height 16 In
Grainger Item #2MV67
Your Price (ea.)
$1,465.20
BrandDAYTON
Mfr. Model #2MV67
Ship Qty.
1
Sell Qty. (Will-Call)
1
Ship Weight (lbs.)164.0
Usually Ships**
1-3 Days
Catalog Page No.
1094
Enlarge Image This item is approved for your organization's custom catalog. Qty. Add a TripleGuardSM Extended Warranty for $199.00 each.
Item
Type
Brushless
Rated kW
12
kVA Rating
12
Surge Watts
15000
Voltage Rating
120/240
Phase
Single
Voltage Regulation (Percentage)
+/-5
Amps @ 120/240V
100/50
HP Required
25
Max. Motor Starting HP
7.5
PTO RPM
540
Speed
3600
Power Factor
1.0
Alternators
Brushless, Revolving Field Provides Reliability, Long Life, Wound with all Copper Windings.
Circuit Breaker
Magnetic Thermal, Capable of Handling the Full Output Capacity of the System while Still Protecting the Unit
Meter Type
Volt/Frequency
Housing
Aluminum
Length (In.)
29
Width (In.)
10 4/5
Height (In.)
16
Application
For Farm and Poultry, Power Take-Off from Tractors, Bulldozers, Trucks as the Prime Mover
Design
Helical Gear Box, Operates Quieter and Smoother for Longer Life
Features
Lifting Eye, Rodent Screen, Recessed Drip Resistant Control Panel, Quick Disconnect Plugs
  • Power Take-Off (PTO) Generators
  • For outdoor use as a standby electrical power supply for farm and poultry applications.
  • Utilizes the power take-off from tractors, bulldozers, or trucks as the prime mover; provides optimized fast response to changing load conditions.
  • New gear box ratio design for quiet, smooth operation. Brushless design, quick disconnect plugs, and high surge power. Nos. 2MU67 and 2MU62 volt meters and frequency meter No. 2MV66 are included. Revolving field alternators are wound with fully insulated and self-ventilating characteristics. Sheet metal has a baked enamel finish enclosure and all sheet metal parts have electrostatically applied zinc coating that enhances paint adhesion and provides rust protection. Main line magnetic thermal circuit breaker is capable of handling the full output capacity of the system while still protecting the unit. Include a lifting eye, rodent screen, and recessed drip-resistant control panel.
  • Voltage regulation Plus or Minus1% for No. 2MV66 and Plus or Minus5% all others
  • Aluminum housing, lightweight, and oxidation-free (No. 2MV66 has steel housing)
There are currently no notes or restrictions for this item.
See Catalog 399 Page for application and/or safety information. This item does not require a Material Safety Data Sheet (MSDS). There are currently no required accessories for this item.
Bob
12/08/2008 4:17 PM
Hi Bob !
That is fine however I'm looking for a smaller unit ( 2kw)that will be operated with a wind power- low RPM @ low torque.
Do you know a vendor for smaller size units?
Thank you
Yigalrr
Good Answers: 123
12/09/2008 10:28 AM
There are some belt drive units used in Emergency vehicles. I will find more info and re- respond.
Bob
Good Answers: 123
12/09/2008 10:40 AM
How does this look. They have also decided to intergrate it with a windmill. Try their website at www.raventechpower.com Good luck.
The Blackbird: On-Board Power
The Engineers at Raven have developed an innovative way to deliver maintenance free, under hood power for tools, lights, computers or communications. The speed independent Blackbird system is lightweight (only 75lbs) and compact and designed to be belt or PTO driven from the engines of a variety of emergency, broadcast, construction and utility vehicles.
The Blackbird features:
5kW 120VAC and
7kW 120/240VAC models
60 Hz pure sine
Compact - only 75 lbs
Clutched belt or PTO drive
No hydraulic fluids, hoses or valves
No inverters or converters
Three year warranty
Frequently Asked Questions
Specifications
PTO Drive Specifications
Supported Platforms
Manuals
Selected Installations
Fill out our on-line request form for more information.
Home | News | Technology | The Blackbird | About Us | Contact
Bob
12/09/2008 12:53 PM
Dear Bob!
Thank you very much!
this seems to be exactly what i need.
Have fantastic life
thank yoou again!
yigalrr
12/09/2008 12:44 PM
Thank you!
Register to Reply 12 comments
Anonymous Poster (1); bob c (3); dadw5boys (1); edignan (1); Sparkstation (1); yigalrr (5)
