Previous in Forum: Is machining beryllium copper hazardous?   Next in Forum: Lost in Translation? Contre dépouille
19 comments
How to Join Glass and Stainless Steel
12/04/2008 4:57 AM
How to join glass & stainless steel .
it should prevent leakage
Good Answers: 183
Re: Join glass & stainless steel
12/04/2008 5:54 AM
Gas? Fluid? Pressure? Temperature? Chemical composition? a. s. o.....
A question can be answered when its content is not fuzzy.
Good Answers: 266
12/04/2008 7:18 AM
The adhesive that holds the metal tab to the windshield of a car which the rear view mirror is attached.
12/04/2008 7:34 AM
Unibond "No More Nails Permanent Strips" sticky pads do this very well.
12/05/2008 8:51 AM
Could you please tell me who said about the arrival to the final destination all used up and admiring the ride? I am dying to know the name of the sage.
Regards;
Nadeem
12052008
May God keep y'all in his blessings Nadeem Butt
Good Answers: 123
12/05/2008 12:13 PM
Ozzb
Bob
12/05/2008 12:29 PM
I dare say not. I have seen this before in some other thread and on CR4 forums. Would some one please tell me?
Regards;
Nadeem
10/27/2010 6:24 PM
This is what im looking for. What did u use?
Good Answers: 123
10/28/2010 6:13 PM
The product is sold as......Rear View Mirror Adhesive.
Bob
10/29/2010 11:02 PM
Thanks Bob very helpful. God Bless
Good Answers: 150
12/04/2008 3:02 PM
If instead of stainless steel you use Invar or Kovar Nickel/Iron alloys or even Inconel X-750 (controlled expansion alloys), and you use a borosilicate glass (low expansion glass), you can cast the glass around the part and get a glass to metal seal like that used for vacuum tubes and such.
Who is John Galt?
Good Answers: 38
Re: How to Join Glass and Stainless Steel
12/04/2008 10:44 PM
With Silicon Glue?
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
12/05/2008 8:42 AM
What are you building? A fish tank?
Silicone caulking.
-why bother doing it wrong when it will be anyway.......
12/05/2008 9:07 AM
Try these guys. We use 'em for custom stuff.
http://www.qsiquartz.com/
Emergency night landings...as you approach the ground, turn on your landing lights. If you like what you see, leave 'em on. If not...turn 'em off.
12/05/2008 9:32 AM
Is this for an industrial application?
12/05/2008 10:10 PM
medical application
Good Answers: 150
12/08/2008 9:25 AM
still need more information. how much pressure? for how long? what is the chemistry of the surroundings? Is this a "wetted" part that must be biocompatible?
Who is John Galt?
12/06/2008 1:43 AM
Can't you seal it like they do thermal windows with Silicon ?
Good Answers: 12
12/06/2008 8:20 AM
This is very dependant on the joint design and application.
There are many compounds that could act as an adhesive or weld type material. I'm sure many of these would be within the medical requirements.
There is the possibility of a mechanical joint as well. Does it have to simply not leak or hold pressure?
Completely capturing the glass or steel portion in a elastomeric seal of some type is again dependant on design.
If you could supply more detail it would help.
01/12/2024 8:12 AM
Double-sided sticky tape?
Register to Reply 19 comments
Anonymous Poster (2); bob c (2); dadw5boys (1); Epke (1); Flying boots (1); gdevine (2); JohnDG (1); Nadeem0430 (2); nick name (1); ozzb (1); pastorjose (1); PWSlack (1); Rorschach (2); Sandip Bodke (1)
