Previous in Forum: Alternator and Induction Generator   Next in Forum: Pressure Relief Valve in Power Transformer
Nuts and Motors
12/05/2008 8:38 AM
Dear All,
Due to carelessness,A nut (5mm) which is used in Motor TB entered inside the motor(30kw,415v) through TB. would it cause any problem.
Kindly help me.
Re: Nuts and Motors
12/05/2008 9:03 AM
If you're very lucky, no. BUT it will probably cause a catastrophic failure at some stage.
Re: Nuts and Motors
12/08/2008 3:40 AM
It would be best to open the motor casing, locate and remove the nut, and re-assemble. It may be that this can only be done in an appropriate workshop facility.
If the nut is of non-magnetic material, turning the motor to the stable-2 position and shaking it may be all that is required to remove it.
Register to Reply 2 comments
You might be interested in: Nuts, Eye Nuts, Nut Runners
