Previous in Forum: Weight distrubution   Next in Forum: low pressure steam~> 40 psi restriction 6"-14" sizing
pipe leaking at valve
12/10/2008 2:00 AM
Dear all,
I need to repair water pipe 8 inch dia., 20 ft lenght which under dam 200 ft. The leaking at the butterfly valve area ( pin hole ). The pipe is about 20 yr.and it's expose ,can be see..Our ideal to do the thickness profile checking and temporary we need to do some patch. The problem major problem is the pipe can't be stop due to only have i have which given the problem. Any suggestion how to repair and we think we need to replace the pipe?!. The pipe is horizotal in position.
Good Answers: 97
Re: pipe leaking at valve
12/10/2008 2:39 AM
What is the possibility of getting divers to fit an isolating valve at the other end of the pipe? It would then be possible to repair the leak or pipe section.
12/10/2008 4:46 AM
Dear Mr hendrik.
the dam water is about 200 ft depth and can't be isolated due to it also supply drinking water to state.But if no option,we will consider@propose to shut down
12/10/2008 7:21 AM
hi,
sir i got your point but little away that 'what is the material regarding pipe?
if metal i am far away!
but if it is a plastic then i put some remedy:
1. for upvc use pvc solution alongwith methenechloride or with acetone in excess quantity, but don't excede more than 28% of 200ml solution respectively.
2. check the working pressure and flow rate again, and is the pipe designed for given
Hand leaver - DIN - 25 to DN - 150 or Gear Operated DN - 200 to DN - 1200
and
pipe mechanical strength.
Important-3. remove that effected part or whole if possible then mark leakage area heat it at (60 deg C for upvc, 95deg C for c-pvc) for 2 minutes take another ring 8 inches wide of SDR series ASTM D-2241 now match the outer dia of your pipe(219.08mm) and the internal dia of that ring and concide it after applying solution before 5-min.
• Please send the proper information for good study.
regards
ahsum haleem
polymer engineer
Good Answers: 97
12/10/2008 8:38 AM
Saddles clamped over the leak may stop the leak but it may also crush the thin / weak wand of the pipe. Local inspection is needed.
Do you have any dam safety legislation to comply with?
What is the possibility of running a syphon over the top to enable complete shutoff?
12/18/2008 9:10 PM
Dear all
Can help me find company doing materializing or patch on steel valve ......cold or hot method or other which can be done. the pipe is 8 ft dia, material ms@cast iron need to confirm later, butterfly valve body sn 400, the pipe used for dam peduh for irrigation.the pipe 200 meter Long , thk profile already in progress done waiting for result. Time frame is very crucial due dry session is coming. The inner pipe suspected erosion due to long service 38 yr.
GOOD BYE....Guru pls reply i in deep shit........
12/18/2008 9:08 PM
Dear all the pipe is 8ft dia. NOT inch. The material cast iron, valve matrial sn 400 thk 25 mm. pipe only can be stop by install damper which located out the dam water side depth 300 ft...required diver to install the plate.
ahsum haleem (1); Anonymous Poster (3); Hendrik (2)
