Previous in Forum: Mobile Robots to Inspect Power Transmission Lines   Next in Forum: Blower
10 comments
Natural Frequency of Vertical Pressure Vessels
12/12/2008 1:41 AM
How to calculate the natural frequency of vertical pressure vessel.?
Please send me link if it exsists related to my question.
Paresh B. Gujarati
Pathfinder Tags: natural frequency
Re: Natural frequency of vertical pressure vessel
12/12/2008 2:29 AM
Good Answers: 58
12/13/2008 7:52 AM
That is a beautifully researched and well written paper. One important factor, however, may have been overlooked. When designing vertical pressure vessels for use in arctic conditions, one must factor in the affects of ice coating on the surfaces of the vessel. This is a very important and often overlooked parameter.
Re: Natural Frequency of Vertical Pressure Vessels
12/13/2008 1:23 PM
In the following handbook, there is a brief calculation for period of vibration T (actual and allowable) for vertical pressure vessels where the natural frequency f = 1/T, and the actual vibration shall not exceed the allowable vibration, and the handbook derives the both formulas/equations:
PRESSURE VESSEL HANDBOOK,Tenth Edition, by Eugene F. Megyesy
Part 1 "Design and Construction of Pressure Vessel"
• Design of Tall Towers, Vibration (page 60).
• Seismic Load, Earthquake (pages 61, 62 & 63).
10/14/2009 11:36 PM
The link to Pressure Vessel Handbook,Tenth Edition, by Eugene F. Megyesy is: Pressure_Vessel_Handbook_10th_Edition-Megyesy
12/06/2016 11:01 AM
sir,
e. megyesy is only give 1st mode shape of natural frequency for vertical vessel.
i need first 5 mode shapes of natural frequency of vessel.
pls suggest which method will used for it.
Good Answers: 68
12/13/2008 8:37 PM
Hello paresh_career001:
I hope these will help. Perhaps you can check some sites against others to check any assumptions and astimates you make.
Good luck and let me know how you get on please..................
PVElite - Complete pressure vessel design to ASME VIII and BS5500 ANSI B 16.5 flange: Computes Pressure rating based on Class, Grade and design temperature. - Vessel Natural Frequency: Computes Natural frequency of the ...
www.chempute.com/pvelite.htm - 24k - Cached - Similar pages
PDF]
038-010_Layout 3 File Format: PDF/Adobe Acrobat
sure, calculate the maximum allowable working pressure,. the thickness required for a specified .... Vessel natural frequency. • Wind and seismic loads ...
www.auto-soft.com.tw/brochue/PVElite.pdf - Similar pages
Guide to European Pressure Equipment: The 'one Stop Manual for All ... - Google Books Result
by Simon Earland, David Nash, Bill Garden, CHW ... - 2003 - Technology & Engineering - 228 pages
This can become a problem if the frequency of vibration coincides with the natural frequency of vibration of the vessel. No method is given in EN 1 3445 or ...
books.google.co.uk/books?isbn=1860583458...
OCRed document
stress limit specified In the ASME Boiler and Pressure Vessel ..... Also, the fundamental natural frequency. in the vertical direction is 28.02Hz. Total 30 ...
ieeexplore.ieee.org/iel5/7981/22072/01027640.pdf?arnumber=1027640 - Similar pages
by HJ Ahn - 2002 - Cited by 1 - Related articles
PDF] 038-029_Layout 1 (Page 1) File Format: PDF/Adobe Acrobat - View as HTML
Pressure vessels fall into two. categories—horizontal and vertical. Each vessel type has its ... Natural frequency calculations. and modal seismic analysis ...
www.hsdphil.com/dls/coade_1.pdf - Similar pages
  • [PDF] Untitled File Format: PDF/Adobe Acrobat - View as HTML
    around the vertical supports. Based on the ratio of periods. between the natural frequency of the vessel and VDE. disruption loading, the DLF was determined ...
    www.osti.gov/bridge/servlets/purl/835923-OjobpI/native/835923.pdf - Similar pages
    by F Dahlgren - 2004 - Related articles - All 6 versions
  • SMPES, LLC A three chamber pressure vessel tower was completely modeled to evaluate 1) if the ... forcing frequency and piping natural frequency is readily observed. ...
    www.smpes.com/Projectsnew.htm - 41k - Cached - Similar pages
    Take care and happy holiday.............................
10/14/2009 11:22 PM
a) Analysis Technique:
Le = Effective Length of stack=
304
ft
92536
mm
Dr = Average internal dia. of top half of stack=
16.75
ft
T = Period of vibration (As per Esco)=1.648 (Le^2) / Dr E0.5
1.7534
sec
f = 1 / T = Natural frequency of stack vibration=
0.5703
cps
T = Period of vibration (C.E.FREEZE))=
2.16
sec
0.4624
cps
T = Period of vibration (As per Megessy)
2.17
sec
0.4618
cps
Ta = Maximum allowable period of vibration (As per Megessy)
6.00
sec
Actual allowable does not exceed the allowable vibration
"My Lord! truly, I'm in need of whatever good that You bestow on me!". Static Eqyuipment Design Engineer
12/06/2016 10:54 AM
sir pls give reference book for above mention 3 method in post..
1. esco
2.e. megyesy
3. c.e freese
09/07/2022 8:56 AM
01/23/2024 10:07 AM
Well, that's a deep vibrail in the bassy profundole all the way up to the highest ever reachie.
With apologies to the late Professor Stanley Unwin.
Register to Reply 10 comments
Abdel Halim Galala (2); Anonymous Poster (1); babybear (1); Guest. (1); nhabibkhan (1); PWSlack (1); swetal7 (2); welderman (1)
