Previous in Forum: preventative auto transformer   Next in Forum: international accredation for electrical licences
eddy currents
12/12/2008 4:31 PM
hi my question is about a 6 wire star delta starter with 3 gland holes can anyone addvise me on arranging the phase sequance . Do i put qty 2 no L1 phase in one gland hole and Qty 2 no L2 phase in the next gland hole and so on . i have qty 6 copex aul glands and 63 mm copex my cable will be 120 sq .
thanks for any comments that might help.....
Pathfinder Tags: eddy currents
Australia - Member - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Electromechanical Engineering - New Member
Re: eddy currents
12/13/2008 2:40 AM
As in other discussions, more info required, like what type of enclosure, what IP rating do you need.
Personally, if I had 120mm cables, and I assume you have SDI (Single Double Isulated) cables, I would have one gland for each cable. If there is limited room in the enclosure then each gland would align to the stud for the contactor or overload. I would make a glandplate using aluminium or other non ferrous material.
Regards,
Trevor.
tooz
Good Answers: 11
Re: eddy currents
12/16/2008 4:24 AM
GA Tooz,
The other option is to cut between the holes with a jigsaw to break the magnetic circuit if ferrous material must be used.
Register to Reply 2 comments
