Previous in Forum: Mystery Medical Equipment - What Is It?   Next in Forum: How Does a Solar Eclipse Affect Wildlife?
Viewing ECG Digitized Signals in PTB
12/17/2008 11:05 PM
Hello everyone. I'm Roey from M'sia. I'm doing ECG analyse by using neural network. A very helpful friend here give me this web link and I find it is very useful.
http://www.physionet.org/physiobank/database/ptbdb/
http://www.physionet.org/cgi-bin/chart
It contains a lot of database and ECG chart. But the problem is the PTB ECG signals are quite blurred as all waves are stacked together. So, I wish to look on the digitized signal given in the web and hope these digitized signals contain every single wave. but i do not know how to see the digitized signals. Please help.
Good Answers: 68
Re: Viewing ECG Digitized Signals in PTB
12/19/2008 8:04 AM
Hello gtroey86:
I am surprised about what you say above. All the ECG machines I have been connected to have adjustments to split the signal, and also to only receive say, 4 out of 8? That is my understanding anyway. I do not know enough to help more, sorry.
Take care and have a wonderful holiday....................
12/19/2008 9:06 AM
Erm.. Actually, I never see the real ECG machine output. I only depends on the ECG charts given by the MIT webpage. It contains all 12 leads ECG signal and 3 leads vx, vy and vz. They are seperated but some of the ECG complexes like R waves are stacked with anothers lead's wave. (in PTB database)
Thanks for your wishes. Same to you. Take care. :)
12/19/2008 8:32 PM
Problems solved.. Thanks you.
Good Answers: 68
12/19/2008 11:27 PM
Hello gtroey86:
How did you solve this problem. Letting others know how you managed your problem with help them in turn!
12/21/2008 12:32 AM
Oh.. erm.. I did not notice that MIT webpage has a function call rdsamp-O-Matic. All digitized signals for every single lead is represented in rdsamp-O-Matic. So, in order to see a single lead waveform, I just copy one of the lead's data(eg. lead II) from rdsamp-O-matic and plot it by using matlab. Viewing ECG signals in Chart-O-Matic is a little bit hard because it mix all the waveform together. I found this solution in the "FAQ" at the physiobank.
Good Answers: 68
12/21/2008 3:24 PM
Hello gtroey86:
I have not used that site before but, have used similar chart sites and they are all pretty much designed along the same lines.
I thought I would not get in touch for a few days and by then you may have sorted out how to use the site!
Take care, and have a wonderful holiday................
Register to Reply 6 comments
