Previous in Forum: earthing systems   Next in Forum: Strange phenomenon at a power transformer
Carbon brushes & sliprings
12/20/2008 2:11 PM
hi friends,
I am not from purely electrical field. I have some doubts about brush & sliprings.Please tell something about purpose of carbon brushes & sliprings in motors. Also about material of brushes.
Thanks in advance
Re: Carbon brushes & sliprings
12/20/2008 3:50 PM
Slip rings simply allow you to connect wires to a rotating part, if you didn't use slip rings the wires would get twisted round the shaft and break.
Brushes on a comutator do a slightly different task, as well as connecting to rotating parts, the 'ring' part is cut into sections such that the brush connects to a different coil as the commutator rotates.
12/21/2008 6:43 AM
Brushes are formulated with mixtures of carbon,graphite, copper, silver and probably a few more but these are the main groups. The mixtures depend on voltage and current carrying capacity also duty cycle and-ability to withstand wear for the particular application.
12/21/2008 7:40 AM
Daer friend,
AC machine need DC supply for magnetic field, located in rotor. We cant give supply through wire to a rotating equipment, so we esu a sliding contact. Brushes touches on round slip ring located on rotor. Brushes are on stator and connected to DC supply.
Graphite.
12/23/2008 11:47 AM
Try removing a simple DC motor from an unwanted battery-operated toy, and dissecting it. The purpose of both will be revealed.
12/23/2008 11:52 AM
Unwanted/broken.
So that's scheduled for boxing day then?
11/30/2010 6:31 AM
there are several type of brushes with different specificationes that are selected for electrical machines due to current , voltage and speed and also material of slipring and climate.
1 hard carbon 2 carbon graphite 3 resin-bonded graphite 4 electrographite 5 metal graphite
www.industrialgraphite.com more information on carbon brushes
Anonymous Poster (1); garth (1); PWSlack (1); sijin (1); user-deleted-1105 (2)
