Previous in Forum: Software for Master-k PLC   Next in Forum: Graphics Cards
9 comments
Acrobat Reader 9
12/22/2008 7:59 AM
Dose any body know how to donload the Acrobat Reader 9 from the acrobat website.
Until now when it start the download drop down the explorer
Thank in advance
Norberto
Re: Acrobat Reader 9
12/22/2008 11:25 PM
HOLA NORBERTO:
TUVE UN PROBLEMA SIMILAR... EN MI CASO FUE "ARCHIVO DE PAGINACION INSUFICIENTE".
PUEDE PROBAR YENDO AL PANEL DE CONTROL - SISTEMA - CONFIGURACION - CONFIGURACION AVANZADA - ARCHIVOS DE PAGINACION - EL MINIMO QUE SEA DE APROX 200 Y EL MAXIMO PRUEBE CON 500 MB.
OTRA FORMA DE OBTENER LAS INSTRUCCIONES PRECISAS... EN LAS OPCIONES QUE SE DAN AL "CLICK" INICIO (HASTA ABAJO A LA IZQUIERDA) APLIQUE BUSCAR, ESCRIBA PAGINACION Y LE DARÁ LA OPCIÓN DE "AUMENTAR LOS ARCHIVOS DE PAGINACION"
OJALÁ LE SEA UTIL
With all due respect
Good Answers: 68
12/23/2008 12:14 AM
Hello YUMASQ:
It would look a lot friendlier if you used the usual lower-case rather than upper. Just a suggestion. Otherwise it seems you are 'SHOUTING'?
No offence intended.............
Have a wonderful holiday......................
12/23/2008 2:05 AM
Hola Yumask
gracias por tu sugerenci, pero no es el caso mio
como fuera hoy ya solucione ese problema
feliz año 2009 nuevo
Good Answers: 54
12/22/2008 11:37 PM
Hello Norberto,
Did you post this same question several days ago?
http://cr4.globalspec.com/thread/30795#newcomments
I gave a few suggestions back there if you'd care to look.
regards,
Vulcan
12/23/2008 1:58 AM
Vulkan
Tahnk you for your advise
it was helpfull
Norberto
12/23/2008 4:08 AM
Hi Norberto
Here is another link to download Acrobat Reader 9.
http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html
This site offers a library of the most popular freeware/software download available. And if you do regular downloads, I would also recommend Download Accelerator Plus 9.0. It will be a great help especially if you have a slow and problematic Internet Connection, With DAP you can download a large size software in several sessions, and being able to continue from a previous download session is a great advantage.
Good luck.
"The more I learn, the more I know the less I've learnt"
12/23/2008 4:13 AM
Thank you for your advise
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
12/23/2008 3:10 PM
If you want to try an alternative.
http://www.foxitsoftware.com/pdf/rd_intro.php
Foxit Reader is a free PDF document viewer, with incredible small size, breezing-fast launch speed and rich feature set. Foxit Reader supports Windows 2000/XP/2003/Vista. Its core function is compatible with PDF Standard 1.7.
In the past, you've had to download a huge PDF reader from another software company, go through a lengthy installation process and wait for an annoying splash window to disappear just to open a PDF document. Moreover, if you want to annotate a PDF document, you have to pay US$299 to buy certain software.
Now with Foxit Reader, you don't have to endure such pain any more. The following is a list of compelling advantages of Foxit Reader:
  • Incredibly small: The download size of Foxit Reader is just a fraction of Acrobat Reader 20 M size.
  • Breezing-fast: When you run Foxit Reader, it launches instantly without any delay. You are not forced to view an annoying splash window displaying company logo, author names, etc.
  • Annotation tool: Have you ever wished to annotate (or comment on) a PDF document when you are reading it? Foxit Reader allows you to draw graphics, highlight text, type text and make notes on a PDF document and then print out or save the annotated document.
  • Text converter: You may convert the whole PDF document into a simple text file.
  • High security and privacy: Foxit Reader highly respects the security and privacy of users and will never connect to the Internet without users' permission. While other PDF readers often silently connect to the Internet in the background. Foxit PDF Reader does not contain any spyware.
I'd also cosider Firfox as your browser.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Good Answers: 97
12/23/2008 7:27 PM
Start with downloading "adobe download manager"
Register to Reply 9 comments
babybear (1); bwire (1); markar (1); Norberto (3); Vulcan (1); willyap06 (1); YUMASQ (1)
