Previous in Forum: Storing Gas Cylinders   Next in Forum: wire specification
Cp/ Cv Ratios
12/24/2008 2:48 AM
Hi Guys!!! Cp/Cv ratio for air is 1.4. If Cp/cv ratio is >1.4 or <1.4 what will be the properties of the fluid whether it will be lighter than air or something..Please help
Re: Cp/ Cv Ratios
12/24/2008 9:42 AM
D'oh..... I need reminding of what Cp and Cv are!!
Re: Cp/ Cv Ratios
12/24/2008 11:18 AM
Cp/Cv is the ratio of fluid's specific heat at a constant pressure to its specific heat at a constant volume.... Hope this reminds!!!
Re: Cp/ Cv Ratios
12/24/2008 7:02 PM
First and foremost, air is a composite of gases, so it can not be used as a standard in this case, given that the Cp and Cv are dependent on the molecular composition and structure.
I would therefore opine that there is and should exist no corrollation of the form you are seeking information on.
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
Good Answers: 143
Re: Cp/ Cv Ratios
12/25/2008 7:21 PM
No. What you suggest is not the case. For example helium has γ = 1.7, with a relative density (w.r.t. air) of 0.14, while argon has γ = 1.7 and a relative density of 1.4.
At the other end of the scale, there is ammonia with Υ = 1.3 and a relative density of 0.59, while carbon dioxide has γ = 1.3 with a relative density of 1.5.
Air is a mixture, but it is primarily a mixture of two diatomic gases (oxygen and nitrogen) and thus has the same γ as if it were a pure gas.
Source for values is Marks' Handbook, 3rd ed.
Re: Cp/ Cv Ratios
01/01/2009 5:36 AM
Cp/Cv is basically dependent on how many molecules are in the gas. Water is 1.3, while the diatomic gases of air are 1.4 and monatomic gases like He and A are higher (I think 1.7).
Beyond triatomic, the ratio doesn't seem to vary drastically from 1.3.
editorgbanalysts (1); Electroman (1); sceptic (1); smkajith1985 (1); TVP45 (1)
