Previous in Forum: Transformer insulation resistance   Next in Forum: starter battery sizing
sizing of a reactor
12/28/2008 10:10 AM
dear all,
i need to size a reactor to be inserted between the nutral bus and the ground in a 480VAC system .
the system is composed of three generating units ,two of them are similar and the third is different.
thanks
Re: sizing of a reactor
01/06/2009 5:59 AM
Huh after so may days I found an interesting querie a very important aspect of electrical engineering system design. Why you require to insert reactor between Neutral bus and ground? to limit earthfault current? if yes, you can use NGR or NGTR. However for LV system NGR are mostly used.
BNDas
