Previous in Forum: sizing of a reactor   Next in Forum: Manual Changeover Panel with Merlin Gerin MCCBs
17 comments
starter battery sizing
12/28/2008 10:17 AM
Dear all,
need to know the calculations made to size a battery to start an engine and the relation between the AH of the battery and the CCA(cold cranking ampere).
thanks
Hobbies - Car Customizing - New Member
Good Answers: 11
Re: starter battery sizing
12/28/2008 11:45 PM
starting batteries are rated by CA/CCA, the AH are a secondary rating, not directly relational to the cranking spec.
sizing depends on stationary, marine, or mobile operation, also diesel or gasoline.
gasoline automobile, typically 750-850 CA (2-3 CA/HP)
diesel medium truck 2,400-3,000 CA (10-15 CA/HP)
(North Central US)
Good Answers: 39
12/29/2008 1:11 AM
To begin with you must know the size of engine you are starting. You need to know the actual current draw of the electric starter motor. Are you trying to start a scooter motor of 50 cc or a heavy duty diesel engine of 12 liter displacement. Will you need to cycle glow plugs for cold weather starting. How much energy does that require? You are not providing enough information for anyone to even make an educated guess.
Typical rule of thumb is the battery should have enough energy to complete three full starting cycles lasting 15 seconds each.
Elnav
12/29/2008 2:14 AM
Dear Ahmed Mansour
Following parameters need to be considered.
(a) Max. current drawn by the cranking motor.
(b) Duration of the current.
(c) No. of continuous cranks which the battery has to support.
(d) Min. temp. at which the battery has to be operate.
As a thumb rule, duration of current is 10 secs. per crank & 3 such continuous cranks have to be supported by the battery.
Aging factor of 0.8 is also to be considered.
Min. operating temp. is must because battery capacity goes down with reduction in temp., since battery capacity is defined at 27 deg. Celsius.
Based on these factors, battery capacity is decided, for the type of battery under consideration.
Thanks and regards
Ashok Toshniwal, Bangalore, India
12/29/2008 10:45 AM
Who cares about any of this AH vs CCA . Just buy what you can afford. 12Volts is 12V
and CCA and AH will be there already.
A high quality battery will have everything you need.
Good Answers: 123
12/29/2008 12:21 PM
"Who cares about any of this AH vs CCA . Just buy what you can afford. 12Volts is 12V
A high quality battery will have everything you need."
My NAPA battery catalog devotes 127 pages to say exactly what you said. What a waist of paper. Why don't you send your information to them, and for that matter, you should share your knowledge with the BCI. They have been making battery selection so confusing for so long.
Thank you for spreading this information.
Bob
12/31/2008 12:44 AM
I COMPLETELY DISAGREE, If battery capacity is inadequate, then the engine might NEVER start because the moment, engine is cranked, VERY HIGH current is drawn from the battery, resulting in SERIOUS drop in battery voltage during that time and loss of charge, which may not allow the engine to start.
In a slightly better scenario, the battery will deliver first cranking current, but if the engine fails to crank ( for whatever reason ) and you try to crank again, then the battery is discharged or does not have sufficient charge to deliver the required cranking current.
12/29/2008 11:33 AM
Hello All:
Traditional battery sizing for IC engine starting need to be critically reviewed in the light of better energy sources such as ultracapacitors which can drive significantly higher currents into the starter motor due to their low ESR, have low temperature dependence and effect more reliable engine starts than conventional batteries.
Amit.
12/29/2008 12:13 PM
trying to be practice,i saw this with very good results:diesel engine 6 litres up to 9 litres use 160 ah, 9 to 14 litres 200ah.Sometimes it needs 24v and somebody will say "in serie conection we have a half charge and we'll need 4 batteries" but may be being that theory wright, in practice thats not necesary and you should keep those values.
Good Answers: 15
12/29/2008 5:33 PM
Ahmed,
While Cranking amps increases with Ampere hours they are not directly associated. The construction of the battery can change the relationship enormously depending on whether the battery is needed for starting or slow discharge use.
Finding the load for your starter may not be easy, as I have found from experience. The best way is to use the engine manufacturers recommendations.
Yosemit3's suggestions are reasonable but are related to the temperatures he is likely to encounter which will be somewhat lower than yours. ( I think this is why he added his location).
Your decision will be difficult to quantify accurately as there are many factors to consider apart from the direct cranking amps such as:-
1. The temperature that you will encounter. Higher temps reduce viscosity of the oil and improve battery start capacity.
2. Your cable size & length. The CCA rating is related to voltage drop the voltage drop on the cable effectively reduces the CCA of the system.
3. The time between charge cycles. This is particularly important to you as in the high temperatures you have in Egypt during the summer 40ºC(?) you will have considerable self discharge, about 20% in 10 weeks.
4. Any loads, even light loads, that may be on while not on charge. This discharge with the self discharge could give you only a few weeks before the battery is too discharged to start the engine.
Good Luck
Chas
12/29/2008 6:23 PM
Higher ah means wider plates and lower internal resistance so that means higher current at starting :Buddy, if you are in problems don't face it like an starter designer forget the idea to face design,be practice or they will kick your ass!go to your supplier and just ask the starter you need for your engine!!
Good Answers: 15
12/29/2008 7:02 PM
Hi Ferquiza,
I face this problem daily. Go learn about batteries then comeback and comment.
Who is going to give us the recommended battery for a 1000hp Mirrlees V12 JS12VT or a 1150hp PAXMAN Velanta for instance not to mention a whole host of other obscure larger diesels?
Chas
Good Answers: 123
12/30/2008 12:23 AM
I for one would try to find the recommended battery for the application, IF we had that information from the OP.
Bob
12/30/2008 5:04 PM
Hi capblanc go to play chess and calm down!
04/05/2023 7:22 AM
A): <...Mirlees...> in the first instance, and <...PAXMAN...> in the second.
Re: starter battery minimum sizing determination
01/02/2009 10:53 PM
Ahmed, Sir:
Start with these battery criteria definitions:
CCA (Cold cranking amps)
The amount of current a battery (any arrangement of cells in series) delivers for 30 seconds at 0 degrees Fahrenheit (-17.7777778 degrees Celsius) while maintaining a minimum voltage of (not less than) 7.2 volts. The higher the number, the stronger the battery and the more starting power it has. (The colder the prevailing ambient temperature, the more that higher CCA is indicated; the warmer, the less important that higher CCA becomes.)
Reserve Capacity rating (in Amp hours)
An estimate of the number of minutes it takes a fully charged battery to dip below 10.2 volts at a continuous discharge rate of 25 amps. For example, a rating of 120 means the battery will run 120 minutes, or 2 hours, at 25 amps load before ceasing to function (nominally, being fully discharged).
These relations, especially the former (owing to Cairo weather), are the basis for your "calculations." However, unless you are building a car from ground up, the engine is not the starting point...should not have been the basis of your question.
Instead, nominal battery power rating and reserve capacity determination should begin at the starter motor. (After all, it is that motor which is matched to the engine and, as well, is the primary load needing to be supplied by the battery during engine starts.)
Because there is no, one unique starter battery for any engine (but, instead, a range of battery powers and capacities that will serve the purpose in various conditions of use), then attempting to calculate an ideal battery for a engine becomes the same as determining the minimum power (that's cranking amps) that will drive the starter motor at rated starter amperage. Beyond that, the CCA and reserve capacity of the battery depends on factors related to your prevailing use of the battery, as well as the conditions likely to be encountered during the battery's life. For example, increases (above minimum) in CCA are less meaningful in warm climate than in frigid climates--purchasing surplus CCA (in Cairo) is likely to be a wasted investment. If long duration of cranking is a factor (such as might be the case, say, where battery will be used in remote locations far from "civilization" and service facilities; or, in conditions of extreme heat such as in a desert), then higher capacity above the determined minimum requirement becomes more worthy of the additional price of the battery.
So, to sum it up, only minimums (especially CCA) need be determined based on starter motor amps rating...and from there you can upgrade (limited only by battery mounting space in the vehicle, and your budget) to higher cranking amperage ratings and reserve capacity; there is no such thing, within practical limitations, as a battery which is too powerful or has too much reserve...because the starter motor can only draw what it requires up to its rating.
01/06/2009 10:29 AM
Refer to the engine manufacturer, with details of local temperature, pressure, humidity and salinity.
01/23/2024 4:59 AM
How about discussing the problem with (a) battery supplier(s) over the telephone, rather than waiting for educated guesses on an international Engineering forum?
That would involve waiting much quicker.
Register to Reply 17 comments
55418UND (1); Amit Raje (1); Anonymous Poster (1); ashoktoshniwal (2); bob c (2); capblanc (2); elnav (1); ferquiza (3); PWSlack (3); Yosemit3 (1)
You might be interested in: Battery Holders, Battery and Fuel Cell Components
