Previous in Forum: best plywood?   Next in Forum: Vaya con Dios, Amigos
Kitchen Remodeling Question
12/30/2008 12:17 PM
Hi,
We are remodeling our kitchen and have found a support beam (two 2x11's spanning 15 feet) where we would like to place cupboards. Will a 6 in. depth 15 feet long steel I beam be sufficient to replace the support that is there?
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
Re: 6 inch I beam support??
12/30/2008 12:41 PM
Without knowing what the whole structure looks like (how it's built) it would be dificult to predict. I would enlist the help of a competent building contractor.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
Good Answers: 101
12/30/2008 1:01 PM
I agree, find a professional. We know far too little information to give any acceptable answer. we can only make numourous assumptions from the information given.
Re: Kitchen Remodeling Question
12/30/2008 2:11 PM
If its on the ground floor, can't you put a supporting wall under the beam, where you know the load is heaviest?
I think builders refer to them as 'ghost wall supports' or something.
12/31/2008 7:04 PM
If you are replacing beams and are unsure of what to use then it would be best to get professional assistance. For the cost of the home, the time it takes to fix and the amount of damage that could be caused by not supporting load bareing walls properly. It makes sense to do things right and by code the first time. Any knowledgable contractor should be able to quickly identify what you need to do. I would also have in a building inspector to look over any work that you or a contractor has done.
Register to Reply 4 comments
Anonymous Poster (1); Electroman (1); RVZ717 (1); Shadetree (1)
