The dryer is a Maytag Model DE313, quite a bit old.
110 Volts Canada, two lines come in each fused with 30 A. L1 goes to timer and feeds the heating element, L2 goes to the E-Motor. L1 always blows the fuse, about ten so far.
When L1 blew for the first time there was smoke all over the basement, mostly coming from the fuse box area. I wonder if that is of significance. It was a thermal fuse. The later standard fuses always blow 'gently' without fuss.
First I changed the "cycling thermostat", then the machine worked fine for about 3 loads, fuse gone again. Replaced, blows quickly. Just to note, the heating element was bust about two years ago. I replaced it and it works fine.
Then I further changed the "High Limit Thermostat" on the heater element. It did not help, the standard fuse is blown again.
Then I opened the plastic box on top of the motor where there are a few contacts by Bi-metal elements. They were all black and singed. I could not buy new ones, as these only come with a new motor, fully assembled. So I cleaned them and put them back again it helped for about 2 drying loads, the the fuse blew again.
I am at a loss what else could be wrong. I have the electrical schematic and wiring diagram but no scanner.
One more point, the timer advances fine when at any cold cycle but does not advance when a hot cycle is selected. When a hot cycle is chosen, the timer is powered differently via the cycling thermostat, as it looks that way to me from reading the diagrams.
Perhaps someone an help, perhaps an appliance repairman? Thanks.
