Previous in Forum: Relay Setting MSB   Next in Forum: Unit convertor & ASA 150# flanges
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
SAE B Two-Bolt Pump Mounting Dimensions
01/06/2009 5:22 AM
Hi All
I have come across a slight dimensional problem with SAE 'B' two bolt pump mountings.
My understanding of the spigot dimensions is that:-
Spigot dia = 4.001" (for the hole that a pump is mounted in) so the pump spigot would be 101.6mm giving a clearance (just).
Spigot depth (now this is my issue) = 3/8" (9.525mm) but some pump manufactures have a spigot protrusion of 10mm !
All other dimensions are not an issue!
Does anyone have a definitive dimension traceable to the SAE? I can only find dimensions from manufactures (and I'm beginning not to trust them )!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Pathfinder Tags: SAE 'B' Dimensions
Good Answers: 19
Re: SAE B Two-Bolt Pump Mounting Dimensions
01/07/2009 5:50 PM
If you're worried about 1/2 mm, you probably need to break down and buy the SAE standard. Sorry.
01/07/2009 6:17 PM
Hi Ried
I was hoping that someone might have access to the standard but.......I think your right, I'm going to have to put my hand in my sky rocket!
Thanks anyway!
Register to Reply 2 comments
