Previous in Forum: 1999 Geo Tracker - No Power   Next in Forum: Montero Sport mileage issue
1998 Geo Tracker - Factor Setting Marks
01/06/2009 9:30 AM
I have a 1998 geo tracker and I think it is out of time, could any one tell me what the factor setting marks are for it, it has a 1.6 5 speed motor. thank you
Hobbies - Car Customizing - Dances with Trees Canada - Member - because I can Hobbies - CNC - too much fun Hobbies - Target Shooting - paper shreader
Re: 1998 Geo Tracker - Factor Setting Marks
01/06/2009 10:13 AM
Lenora
I think it best you find someone to hook up a test book (diagnostic computer) to the car to find which component has failed. Setting the timing on modern vehicles with computer controlled engines is not as simple as pointing a strobe at the crank shaft and adjusting the distributor. Considering the age of the car I would suspect component failure, but without knowing the mileage that would be a wild guess.
Don't panic, it could be as simple as an air temperature sensor, or maybe an exhaust sensor, which is more likely.
Most local independent automotive repair shops will be able to diagnose the problems for you.
Good luck
Kevin
Kevin "Dances with Trees" Willey
01/06/2009 10:56 AM
Thank you Kevin
01/06/2009 9:41 PM
5 degrees BTDC but Kevin has good info as there is a special procedure to adjust the timing. The proper procedure is explained on the emission label under the hood. If you would give a little more information in the way of symptoms then you could probably receive more info. Hope it helps.
Jim
Register to Reply 3 comments
Dances with Trees (1); Jspeop (1); Lenora (1)
