Previous in Forum: Elevator System   Next in Forum: Testing High Resistance Grounds
formula for current
01/06/2009 3:37 PM
i need formula to calculate current of cable
Try and fail better than fail to try
Re: formula for current
01/06/2009 3:50 PM
Hello,
you can find in the link http://en.wikipedia.org/wiki/Current_density
Actually you can use I=j*C
Where:
I - current of cable (A)
j - Current Density of metal (A/mm2)
C - Square area of cable (mm2)
example: Cable 16mm2 cooper (j=2) => I= 2*16= 32A (max)
Regards
01/07/2009 8:34 PM
No need. Chose a cable size and look it up in a table.
01/09/2009 6:20 AM
you can see it directly from table.
Other wise if u know the power or voltage than u can calculate current by formula
I=v/r , p = I^2*r
r resistance , v = supply voltage , p = power
u can get r by ohmmeter , either u can calculate it by
r = rho *l/ a
l = length
a = area
rho = resistivity of material
01/10/2009 11:50 AM
thank you every body
Register to Reply 4 comments
Anonymous Poster (2); dbt (1); wareagle (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
