Previous in Forum: Micro Vu Squareness Checks   Next in Forum: training Intools
Dew Point on Drier Machine
01/06/2009 11:07 PM
Hi every body,i have difficulty in my job.Drier Machine often dew point,what mean?
Thank You every body
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: Dew Point on Drier Machine
01/07/2009 12:24 AM
Would you please to provide more details for your request? It's so hard to decipher. Has your machine equipped a dew point sensor that shuts its down?
regards, caramba
South Africa - Member -
Good Answers: 12
01/14/2009 1:50 AM
Hi there,
Dew point is the temperature to which air must cool, where the water vapour in the air will condense into water. Thsi will be at a constant barometric pressure.
For more information: http://en.wikipedia.org/wiki/Dew_point
Regards,
Craig
02/13/2009 1:41 PM
I did not understand your question.You want to know the definition of DP or ur machines are producing wet product? i.e if air compressors are producing wet air then you have to cool to condense and drain the water.The DP dew point is the temperature at which water vapors convert to drops.If there are more water vapors in process these will condense easily i.e +10C.If less water is there in process then dewpoint will be relatively negative i.e -10.Normally more dry process is required means less water in process.
iak
caramba (1); craigza (1); khania58 (1)
