Previous in Forum: Watching Water Freeze   Next in Forum: Recovering data from a damaged hard disk
What's the ASME Minimum Tubing Thickness for Orbital Welding?
01/07/2009 9:29 AM
My supervisor has told me that when orbital welding 1/4" .035" wall tubing, to meet ASME section IX it must be 2 wall thickness (.070") +/- 25%.
I did my training under Ernest Benway at SWAGELOK and he said full penitration, and minimum 2 wall thickness' wide the bead must be. Thats it.
I have the code but I can't find anything that indicates +/- 25% of the bead width.
If this is in fact true where can I find it in the code?
CBraet
Re: What's the ASME Minimum Tubing Thickness for Orbital Welding?
01/08/2009 9:12 AM
Are you butt welding two tubes together or welding a tube to a tubesheet.
In general Section IX doesn't cover joint design. That would be part of the design code (Sections I, III, VIII-1, B31.1/2/3, etc...)
Section IX gives a range for qualification. If you qualify a WPS on 0.035" material, it will generally be qualified from 0.5x to 2x of the qualified thickness (0.017~0.070"). Likewise there is also a range for the tubing diameter.
When we do tube-to-tubesheet WPS qualifications, we generally have to do one for every tube diameter - tube wall - material - joint configuration combination that we use.
01/08/2009 9:40 AM
Thanks for the response Lawrence,
Tube to Tube, When I coupon in, and cut open the weld after and inspect the inside, I measure the inside weld bead width. Ernie Benway said it must be minimum twice the wall thickness ie .035"Wall , .070" minimum to pass Section IX or it is a failure.
Cbraet
07/01/2009 8:30 PM
The 2 X rule is for the welding procedure qualifications, PQR, as well as the welders qualification, it means that if the procedure you were qualified under is for 1/4" .035 Wall tubing, you are only certified to and qualified to perform welds for up to 1/2" .070 Wall tubing, Nothing bigger.
vmg
“A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.”: Douglas Adams Quote
Register to Reply 3 comments
Lawrence (1); Simon&Garfunkle (1); vmgarcia (1)
You might be interested in: Plastic Tubing, Rubber Tubing, Tubing
