Previous in Forum: Steam Turbine Questions   Next in Forum: EN8 MATERIAL HARDNESS
Converting Air Pressure Measurements
01/09/2009 12:37 AM
Greetings CR4 members,
There is a specification we got for 1600cc of air pressure.
Any suggestions or answers regarding the conversion of this pressure to BAR or PSI
True strength comes from the loss of ignorance,even in martial arts.
Re: Air pressure clarification
01/09/2009 4:15 AM
You can't. (unless you had more information such as number of moles / weight / temperature)
1600 cc is a volume: cc = cubic centimeter
You need a seperate/more detailed spec to indicate required pressure.
01/09/2009 4:31 AM
yup...agreed upon..but we have a tender dowcument which states this and i presumed that they cant be wrong..guess they can be after all !!
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
01/10/2009 11:40 AM
Unless there is other information in your document, they are wrong.
CC's is a volume measure. PSI, Pascals or other pressure measures are force per unit area.
Speak softly and carry a big stick.
03/08/2013 9:40 PM
Dear Mr. talos,
We have come across few cases where the tender Document itself is wrong. Some times MISTAKE(S)/ERROR(S) DO HAPPEN. We have to excercise our CAUTION/ALERTNESS.
As other CR4 members, expressed "cc" is VOLUME.
DHAYANANDHAN.S
Re: Converting Air Pressure Measurements
01/10/2009 7:55 AM
Here is a Free Program called Convert:
http://joshmadison.com/article/convert-for-windows
Which will handle BAR to PSI. (1 BAR is 100 KPa - 14.504 PSI)
The nice thing about Standards is there are so many to choose from.
01/12/2009 8:54 AM
1600cc of air pressure for what? Many times you can use assumptions to arrive at your answer. Like, assuming the power delivered, the size of the piping and the ambient temperature, you can find a relatively close answer.
01/12/2009 3:28 PM
cc is most often a designation of volume, cubic centimeters, not a designation of pressure. Volume cannot be converted to any pressure format. You require more data.
Register to Reply 7 comments
Anonymous Poster (1); dhayanandhan (1); nathaniel1105 (1); standarded (1); talos (1); Tom Kreher (1); Tonymech (1)
