Previous in Forum: I/O Checking   Next in Forum: Rubidium Frequency Standard
Dp type Steam drum level transmitter
01/10/2009 5:27 AM
why we select nigative range of callibration in DP type level transmitter used for steam drum level.
Re: Dp type Steam drum level transmitter
01/10/2009 11:19 AM
Because the low pressure side of DP Tx has wet leg, when it is used for steam drum level.
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
01/10/2009 1:29 PM
because the steam condensate will always fill the LP leg and when LP side goes hi dp transmitter goes negative, in order to remove this erratic reading .We always first fill with condensate on LP side and adjust zero supression and bring the signal to zero this is the LRV of the smart Xmtr and by giving pressure to HP side to the given height or span is the URV of the smart Xmtr .
hope you get the proper answer
01/18/2010 11:16 AM
I HAVE A CASE TO MEASURE LEVEL IN FORM OF DIFFERENTIAL PRESSURE
LEVEL TO BE MEASURE IS LOW 437 mm & HIGH 1190
FLUID IS WATER
WHAT SHOULD BE THE RANGE OF TRANSMITTER I SHOULD GO FOR?
i AM ASKED TO SELECT A ROSEMOUNT DP3051 MODEL
VESSEL OVERALL HEIGHT IS 1400
07/01/2024 7:24 AM
Absolutely fine. If that can take place WITHOUT SHOUTING then readers here trying to get some sleep will not be disturbed.
Anonymous Poster (1); find2am (1); PWSlack (1); SSS1104 (1)
You might be interested in: Level Sensors, Drum Pulleys, Drum Heaters
