I would like to ask if there's a way to calculate the distance travelled by pig from the pressure gauge readings on the launcher to ensure that the pig is travelling at the specifed speed as per the specification
OR
Other way we can keep a note of time for same of say 1 m after the stabilization of the pig run and locate the pig by pig tracker/ locater and measure the distance in chainage keep on multiplying the same for a given distance travelled and pressure indicated.
The later assumed process surely would not help the Sub-Sea Pipeline or it may if you measure it on the risers!!!
