Previous in Forum: Pigging and Gauging   Next in Forum: Free Cooling - Application Examples
17 comments
Pump Alignment
01/12/2009 4:18 AM
Hi,
What precautions must be adhered to while doing pump alignment i.e. from placing on foundation to aligning pump with piping connected?
Cheers,
You can't save a file naming "Con" - Expert
Good Answers: 19
Re: Pump Alignment
01/12/2009 4:37 AM
You need to align the Pump with the Motor Shaft. Check the balance of the rotating coupling. If misaligned you hear Ke Ke Ke Ke KE KE KE KE KE..... and it gets louder n louder . Then KAAAAAAAK. That means the Shaft jammed with the Rotar and that means YOU LOST THE MOTOR.
Re: Pump Alignment
01/12/2009 4:49 AM
Thanks, Ducon!!!
I had expected some kind of guidelines or procedure!!!
Cheers,
Ash Bandy
Good Answers: 19
Re: Pump Alignment
01/12/2009 8:55 AM
Honestly I learnt it this way and it was an EXPENSIVE first-experience. My best advice take your male/female coupling on a lathe and run it to see if they wobble or not. Ask the lathe guy to balance it. Then align & level the the pump & motor with the coupling. Then you are CAREFREE.
Good Answers: 103
Re: Pump Alignment
01/12/2009 4:58 AM
I really love this type of answers. Alignment of rotating equipments are a basic thing that we learn-
Ducon: did you record the noises or made-up ? any way AVI files can not be loaded here. You missed out the noise when the overstreesed flange bolts fail - may be
inlet - whooooooo (air suction)
Outlet - Hoooooosh (oil spray)
Off topic: How can anybody help when we dont know the pump size, capacity, fluid, temperature. foundation, and so on.
All the instructions i am sure are on pump manual.
Just try to align Boiler feed pumps in the same way as a 1/4 HP coolant pump and you will understand what I mean.
But Ducon principle is applicable for both why don't you expand it to be a "Ducon's law of alignment diagnostic"?
- Align pump and Motor to specified value, depending on your procedure and tools available with coupled condition. uncoupled condition
- Tighten foundation fasteners and recheck alignment.
- Ensure the pipelines (based on their supports, rigidity etc) are aligned to flange and sufficiently nearby (depends on the pipeline design how nearby it should be, we just prefer that it should not create a stress on flange joint when we tighten flange bolts
Good Answers: 19
Re: Pump Alignment
01/12/2009 8:58 AM
"Ducon's law of alignment diagnostic"? Good one. Thanks sb.
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: Pump Alignment
01/12/2009 5:11 AM
Alignment is essential in order to ensure long service life of rotating equipment and their components. Incorrect alignment is one of the major causes of machine failure.
PRE‑ALIGNMENT CHECKS.
Several things cause misalignment, and should always be checked before beginning an alignment. They are as follows:
· Is the machine base level?
· Is the machine base, shims, and pads on the feet of the machine, clean and free from burrs?
· Is the machine level?
· Is there any pipe strain?
· Are there are any soft feet?
· What is the end float?
· What is the bar sag.
When all these checks have been carried out the alignment can begin.
The four steps of any alignment are:
· Remove vertical angular (face) misalignment.
· Remove vertical parallel (height) misalignment.
· Remove horizontal angular (face) misalignment.
· Remove horizontal parallel (side to side) misalignment.
After steps 1 and 2, and shimming (the adding or removing of shims) is completed, steps 3 and 4 are done at the same time by moving the jack bolts (sideways movement).
Look over to the next challenge
Re: Pump Alignment
01/12/2009 5:01 PM
Thanks for a step by step pre- alignment check method.
Only thing I forgot to mention to check the soft foot on the motor and a deflection between 0.05mm ~ 0.08mm would be happily acceptable.
Master levelling on the discharge flange.
Torquing of hold down bolts.
face and rim alignment.
Re: Pump Alignment
01/12/2009 8:12 AM
The only caution I would consider other than the input you have received is in the area of how you read the alignment. If you are using standard dial indicators or feeler gauges the face readings are more significant on small diameter couplings. If you are reading on a very small diameter you may want to fabricate a rig to extend the diameter. I think the reason is obvious.
If you fail to follow through, you will fail.
Re: Pump Alignment
01/12/2009 5:07 PM
I agree Otha. Of course it all depends what kind of alignment the client has specified like conventional type, reverse (Graph plotted) or laser. Also, the arrangement I have made is like ould be used for couple of sizes and then the next rig further sizes.
Re: Pump Alignment
01/12/2009 10:53 PM
Dear Friends,
It is better to tell you the procedures how you can align the specific machine. You can contact the machine vendor and ask HOW!!! For example, how to mount the pump on the foundation, how to align the pump and motor, etc,.
I feel that your question the work flow of pump installation.
When the pump arrives in the site, provided that anchor bolt is already there (embeded type, other type such as box type does not need much of work)
1. Remove all dirts and dust on the foundation and clean it as much as possible. Mount the pump on the foundation. Check the suction & discharge nozzle location along with the black ink line on the foundation. Check the horizontal levelling of the pump baseplate. Everything is completed? Then, pour the groutings. Wait for 2-3 days for curing of the grouting.
2. Pre-alignment check : This is to check the horizontal parallality between centerline of pump baseplate and centerline of pump-coupling-motor. (1st Alignment) Offset shall be corrected with the shim plates as needed.
3. Pump alignment check : Pump suction and discharge pipings are connected. Now you are really doing real pump alignment!! Offset shall be done by moving, shim plating and other way.
4. Final alignment check : This is to confirm the piping does not give too much piping load to the pump. Disassemble the pump suction & discharge piping from the pump. Check the pump alignment that you have done at 3 stage (Pump alignment check) If the result is acceptable? then it is done. If the Alignment is ruined, Repeat 3 again until you get the satisfactory result at this stage.
So, in conclusion, you need 3 times alignment of the pump during the construction stage.
Re: Pump Alignment
01/13/2009 6:45 AM
If you have to allign on a regular basis, a quality laser allignment system will pay for itself many times over.
Re: Pump Alignment
01/13/2009 10:39 AM
for us it was cheaper to buy some flex couplings (comes balanced at operating rpm)
we tried playing around with shims for alignment/to reduce vibration but the flex coupling seemed to worked well for us
Re: Pump Alignment
01/16/2009 7:51 AM
The problem with relying on flexable couplings to compensate for poor shaft alignment is that deflecting the coupling adds load to the bearings. Given that the life of a rolling element bearing is inversely proportional to the load cubed, that will drastically reduce the bearing life.
From a life cycle cost point of view, you are much better off aligning the shafts correctly.
Also, for a pump or turbine, you don't want any piping strain. If you have strain, you have the possibility of distorting the casing and reducing bearing life or worse. I once saw a 2000HP pump bound up by piping strain.
jim
Good Answers: 19
Re: Pump Alignment
01/16/2009 10:53 PM
2000HP pump bound up by piping strain. Good Lord! I bet the guy responsible left town and still untraceable.
Re: Pump Alignment
01/17/2009 11:07 AM
It was a shipboard condensate pump. The mechanics who installed it found a 3/4 inch mismatch between the pump discharge flange and the piping. Instead of re-targeting the piping, they used a chain fall to pull it into alignment.
jim
Re: Pump Alignment
01/19/2009 12:03 AM
Why can't we go with a designed flexis at suction and discharge??
Re: Pump Alignment
01/19/2009 6:40 AM
In most cases you can.
jim
Register to Reply 17 comments
Anonymous Poster (1); Ash.Bandy (4); burt (1); ducon (4); jimtaylor (3); otha (1); sb (1); user-deleted-1104 (1); yeonhoyu (1)
