Previous in Forum: UPS   Next in Forum: Light weight induction motor
Using LEDs with a PNP Proximity Sensor
01/13/2009 10:01 AM
Hello friends,
I want to glow one 24V DC LED on output supply voltage of PNP proximity sensor. i.e. when proxi get switched, LED will glow. I tried by giving o/p of proxi to led & negative of DC;but failed. Help for this problem will be highly apreciated.
Thanks in advance..
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: Using LEDs with a PNP Proximity Sensor
01/13/2009 10:33 AM
Here's conventional scheme for PNP sensor. I'm supposing you have something like. Are you sure the LED fits to 24V? If you're not, try out ballast resistor (shown as phantom).
01/13/2009 11:28 AM
caramba, I think you'll find your LED is the wrong way round - it must be conducting (forward biased) to light up.
01/13/2009 11:47 AM
Oh Yes, JohnDG. You're absolutely right. I was mistaken with polarity as I used to work only with NPN sensors in my last projects. Thanks you've corrected me.
So hope it's right?
01/14/2009 10:13 AM
yes sir,
These leds are of 24volts; working well with DC supply.
Register to Reply 4 comments
caramba (2); JohnDG (1); SAN00 (1)
