Previous in Forum: When Technology Fails Us   Next in Forum: The Two-Tailed Skink
12 comments
Home Automation Control
01/18/2009 3:31 PM
I want to control my homes solar heating simply and inexpensively with my lap top.
I dont want to pay thousands for software like LabView but want the convenience of
graphical interface and software to run on a PC. What low cost or public domain software is out there for me to use?
I am open to suggestions.
I need to control relays, read tempatures - 1wire, rs-232 devices etc.
Don
Good Answers: 19
Re: Home Automation Control
01/18/2009 11:07 PM
Makes me remember what a client of mine said, " I want the best of the best equipments for my plant FREE".
01/18/2009 11:46 PM
I don't have any personal experience with this but know of some people who play around with this for home automation--->http://www.parallax.com/tabid/441/Default.aspx. I don't think it's going to come with a graphical interface, though.
As far as graphical interface, I saw an ad for this in the new New Equipment Digest. It's from Rockwell Automation so I don't know how cheap it is----->http://www.rockwellautomation.com/rockwellsoftware/performance/viewpoint/
I hope this helps.
Good Answers: 204
01/19/2009 2:18 AM
its easy. just build your own interfacing to your laptop, and write the pid hvac controls yourself.. thats the cheapest. then all you need is to buy the appropriate sensors, actuators and relays, and wire them up to your custom I/O controller. Its a weekend project and shouldn't cost more than few grand.
Good Answers: 62
01/19/2009 12:16 PM
Tsk tsk
Snarky sarcasm?
Unfortunately correct. We could do the software opensource, but the cost of equipment...
Good Answers: 204
01/19/2009 3:38 PM
yah... guess I'm not gonna get a GA for that one... but hey, I earned two "TSK's..
Good Answers: 62
01/19/2009 3:59 PM
Yeah, what goods a rating system that only counts above zero!
01/20/2009 4:43 AM
Maybe you'll earn the rest of the Elephant eventually.
01/19/2009 5:36 AM
In the good old days of QuickBasic it would have been a breeze.
Computers are now overcomplicated to the point of uselessness in terms of quick usefull user-built interfacing.
Good Answers: 204
01/19/2009 10:58 AM
as I recall another thread, software is overrated for process control anyway
Good Answers: 213
01/19/2009 3:32 PM
A place to start looking might be SCIENCE HOBBYIST (http://www.amasci.com) or a number of other amateur science project sites which can give you some very basic ideas about where to start. Controlling relays will be no problem- this can be done by controlling the control lines on the RS232 connector (IF your lap top is old enough to still have this), or, better the old parallel printer connection (which means your laptop is even OLDER!). Getting the temperature information into the computer will be the tricky thing- I use a DMM with temperature capabilities, which means I need another RS232 or a USB port for this. If you want to monitor temperatures in multiple separate locations simultaneously, then you are talking some serious development work... Any decent programing language (i.e., c, Forth, some versions of Basic) will give you all of the functionality you need, but it will take some research to determine exactly how. This is not a project I would undertake just to save money, but it would be fun to do it just to say that I have.
08/21/2009 12:04 PM
You guys like to do thing the hard way! Use a crestron single room processor called a QM-RMC. These can be bought through www.tuffsystems.co.uk who are Home Automation specialist and they have 2 x RS232 control ports, 4 x Digi/Analogue IO ports for sensors and an IR output for IR control. Furthermore there is IP connection for your network and after a little programming you can do what you want, when you want, however you want. These only cost £600 so cheap solution I'd say!
05/29/2014 1:07 PM
It's pretty easy to get an inexpensive climate control without breaking the bank.
There's a company called ICP-DAS USA that specializes in home automation and remote device control. They have touchpad interfaces that connect to your data acquisition units and allow you to adjust and monitor temperature and other. The units come equipped with HMI Works software for the graphical interface you were talking about. (Click on the items below in blue for more info):
TOUCH PAD CONTROLLERS
There's also an array of data acquisition units that convey temperature, power and current, based on your connected sensors. These can plug into your PC for monitoring through either a wired connection or through an Ethernet connection. Both options come with their own free software:
WIRED DATA MONITORING
WIRELESS DATA MONITORING
ETHERNET DATA MONITORING
They've got strong technical support and are helpful.
Anonymous Poster (1); chrisg288 (3); cwarner7_11 (1); digguru81 (1); ducon (1); edignan (2); JappyKnees (1); user-deleted-1105 (2)
