Previous in Forum: Automatic Batch Control of Fuel Mix   Next in Forum: how do you keep track of children
13 comments
R-410a in R-22 systems
01/19/2009 1:57 PM
In theory, what would happen if you introduced a about 10 ounces of R-410a into an R-22 system? A group of us were having the discussion and no one had a clue. If you injected that small of an amount, would it have no effect, positive, or a negative effect?
How is it that my measurement of 8" is different than hers?
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: R-410a in R-22 systems
01/19/2009 2:37 PM
I'm sure something would change.
I don't remember the name of it, but one of the basic gas laws says that the total pressure of any mixture of gasses equals the sum of the individual vapor pressures of each gas.
The vapor pressure of any gas depends on its density. Unless R-410a and R-22 have the same density, they most likely will not have the same vapor pressure.
You should be able find the information online you need to help you finish out this theoretical exercise. Personnally, I wouldn't even think of trying it for real, for if the resut is a sudden and sharp increase in system pressure, you won't be able to complete the operation without an explosion and the release of toxic gasses.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
01/19/2009 2:48 PM
I could see the disaster if you changed all the refrigerant to R-410a, but what are your thoughts if it was only a few ounces of 410 in a 5 ton r-22 system?
Good Answers: 213
01/19/2009 4:27 PM
A few months back, a client of mine had a couple of refrigeration units installed by some less-than-qualified technicians who wound up using the wrong refrigerants in the units (I don't remember which refrigerants were used). Both systems had to be vacuumed and flushed a couple of times with the correct refrigerants, because of a concern over the effect of mixing them. I don't know for sure what the effects would have been, but the client was not willing to find out through experimentation...
01/20/2009 12:02 AM
Charging about 10 ounces of R-410a into an R-22 system will cause the head pressure, suction pressure and evaporator temperature to go up. How much will be determined be the total charge of the system and the type of expansion valve, either TXV or Cap tube.
Hobbies - Car Customizing - New Member
Good Answers: 11
01/20/2009 12:02 AM
r410a is the ozone friendly "replacement" for r22.
it is incompatible with the mineral oil used in r22 systems, using a synthetic oil specific to the application.
its expansion and absorption characteristics are different as well, requiring a compressor with different expansion ratios, as well.
r410a requires smaller tubing, and different characteristics in the condensers, and evaporators, as well
bottom line: recover the refrigerant to a waste cylinder, and purge the oil as well. a commercial flush, such as r11 should suffice. evacuate, to ensure a clean system, and recharge both oil and r22
recovery of mixed gases must be to code, and routed to a licensed agent
http://www51.honeywell.com/sm/410a/about-us/az-story.html
01/20/2009 12:15 AM
I agree that the tubing is smaller for a 410 system, which is why my guess is that nothing would be affected in an r-22 system due to pressure temp relationship. But since this is a question that I can only guess at I am acceptable to being told that I am wrong. haha
01/20/2009 5:57 AM
YOURS IS THE MOST CRITICAL POINT.
Hobbies - CNC - New Member Canada - Member - Finaly got around to it.
Good Answers: 12
01/20/2009 3:58 PM
Yosemite3 is correct, except R-11 is banned under the Montreal protocol. There are other flushing agents available.
01/21/2009 5:55 PM
Its actually " R11X" flush, an ozone friendly/ EPA compliant acceptable way to rid the old oil (but not in all applications). I believe NuCalgon makes it.
10/10/2016 8:55 PM
I recently encountered this same problem, except the tech added 3 pounds of R410a to a 2 ton R-22 system.
Don't have a problem purging the refrigerant gas, evacuating the system and changing the dryer, but what has happened to the mineral oil? Has it been ruined by the R410a, or will it be ok once the R410a is removed? Since the compressor is fully hermetic there is no reasonable way to drain the oil and replace it with new mineral oil.
Do you have precise knowledge of what will happened to the oil in this situation? Most of the comments I see above are guesswork which is fine, but wont stand up in a legal dispute.
01/20/2009 11:24 PM
If R-410a is added (by mistake) to an R-22 system, ALL effects are detrimental to the performance of the system designed for R-22, In residential cooling, R-410a operates at +/- 400 psig condensing while R-22 is 225 psig. It takes much more liquid R-410 evaporating to absorb as much heat as R-22 . The coefficient of performance (thermodynamic efficiency) of R-410a is lower than R-22 for typical home cooling.
Petroleum lubricating oils have poor solubility in R-410a so esther based lubricants are required.
R-22 is extremely stable in service. R-410a is EXTREMELY sensitive to moisture, flux, and decomposition by too much heat.
R-22 costs some $2/#, R-410a is >$10/#
Keith E Bowers, PMP
10/15/2010 9:49 PM
I want to ask the opposite - can I use R22 in a system designed for R410a? I am living in a developing country where R22 is readily used and available - R410a is not. I have a R410a split system AC unit which has been incorrectly installed and needs to be regassed although I can not get any R410a to recharge it. From what I have read it seems that the only adverse effects of regassing with R22 (apart from the environmental ones) would be a slight decrease in system effieiency. Any advice?
Cheers,
Ben
Good Answers: 12
10/16/2010 9:47 AM
There will be guarantee that it will work. Oil will not be a problem as R-22 is compatible with POE oils. The metering device may need to be changed or adjusted to suit 22. The compression ratio for the two refrigerants are similar.
Work case scenario is that you destroy your compressor by overcharging or undercharging the system.
The best case is that it works well enough for needs needs, and you can change it back when R-410 becomes more available.
Register to Reply 13 comments
3Doug (1); Anonymous Poster (1); cwarner7_11 (1); DRFREON (2); Enersol (2); HVACR Drill (1); Icarus (2); Keith E Bowers (1); Wayne Davis (1); Yosemit3 (1)
