Previous in Forum: High-Temperature Glow Plug for Catalytic Reactor   Next in Forum: Pre- Commissioning Of Derrick Barge
Air Cylinder
01/19/2009 2:32 PM
If I am using a pneumatic actuator to actuate a gripper to grip inside a pipe, is the force exherted by my pneumatic cylinder(F) independent of the surface area (contact area) of the gripper (A)?
thanks!
Re: air cylinder
01/19/2009 2:47 PM
Yes, its independant.
Re: air cylinder
01/20/2009 12:04 AM
Yep independant.
Friction force = the normal force x coeff friction between you gripper and pipe. Unless you've got teeth that bite into the pipe or something.
Do or do not, there is not try, but there is failure...
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
Re: Air Cylinder
01/19/2009 11:14 PM
Hi Vscid
Yep, the force at gripper A is dependant on the force supplied by the cylinder ± any mechanical advantage/disadvantage in the lever mechanism involved within the gripper and the angle of the applied force.
The force applied by the cylinder (in turn) is dependant on the air pressure differential applied to the piston of the cylinder (or it's rod or it's annulus area < piston minus rod>).
Don't know if this helps as there are a lot of variations possible here!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Register to Reply 3 comments
aXiom K (1); Beej50 (1); V.Daniel (1)
