Previous in Forum: Plastic Screw Torque   Next in Forum: Runner Design for a Francis Turbine
11 comments
Compressed Air Discharge in Water
01/20/2009 2:25 AM
How to clculate compressed air discharge (CFM) in normal water through a line of 1 inch dia at 6 bar gauge pressure?
Plzzz.... suggest.....!
Regards,
Sanjib
Good Answers: 19
Re: Compressed air discharge in water
01/20/2009 3:57 AM
Install an Air Flow meter and read the CFM reading.
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
Re: Compressed Air Discharge in Water
01/21/2009 1:49 AM
If you want to Calculate (as opposed to comment at #1) there is a standard formula (for a discharge into air), however, into water will require a modification and the first thing we need to know is:- at what depth.
At around 60 meters depth (gauge), it will be zero!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
01/21/2009 3:11 AM
Thank U Beej50, This is what is actually showing me the way. Plz suggest the same for a depth of 1 Mtr. as wel as the calculation procedure. Regrds, Sanjib
01/21/2009 4:18 AM
To determine air flow through an orifice:- V=CK√P Q=AV VP=(V/K)²
Where:
V = Velocity in feet per minute (fpm)
C = Orifice Coefficient
K = Constant = 14,786 when P is expressed in In. Hg
21,094 when P is expressed in PSIG
4,005 when P is expressed in In. of Water
(Above constants are based on an air density of 0.075 lbs/ft )
P = Pressure differential across the orifice
Q = Flow rate in cubic feet per minute (CFM)
A = Total orifice area expressed in square feet
VP = Velocity pressure (units are those of pressure)
Now I suspect that all you have to do is modify the atmospheric pressure (K) to that of 1 meter of water BUT, I am not a mathamatician and only use these formula verbatum! Also, I've never needed to work this problem out before!
Your best option is to wait until someone else jumps in here! A mans just gotta know his limitations!
I hope this helps a bit!
01/21/2009 4:29 AM
You will also need this:-
Coefficent C for orifices under vacuum or pressure flow:-
Bugger! It just dosent want to paste into this field!
I will email to your postbox!
Good luck with it!
Good Answers: 40
01/21/2009 3:28 PM
Further-to Beej50's posts ... in the Commercial Diving industry, for underwater grit blasting, we calculate "Pressure-at-the-nozzle" including the figure 0.45psi per foot of water depth. So Beej50 was spot-on for 60 meters...
For anyone interested: It really DOES require appropriate training to operate such equipment ... underwater as well as topside, or you can end-up with disastrous results...! <click link
[I'm waitin' to hear more about that nozzle coefficient factor...]
Good Answers: 19
01/21/2009 3:50 PM
FLOW OF AIR SCFM , SIZE ORIFICE 1" AT 80 PSIG = 1177 SCFM, 90 PSIG = 1305,
100 PSIG = 1433.
SOURCE : http:/www.trident.on.ca/orifice-air-flow.htm
Good Answers: 68
01/21/2009 7:45 PM
Hello sanjib:
Can you tell me what the ID of the hose is please?
Take care.................
01/22/2009 2:36 AM
Hi, babibear, The ID is 25.26mm as measured. Waitn 4 ur reply. Thanks... Sanjib
Good Answers: 68
01/22/2009 1:44 PM
Hello Guest........
OK. Am busy trying to sort it.
01/23/2009 1:44 AM
You may wish to actually physically test this. That much CFM will displace the water above it and cause surging. The weight of the water will keep trying to fill the hole and gravity will force the air up. The pressure will go from maximum to minimum as the air displaces the water above it. Pressure drops and the water rushes back in.
or not, a meter may be deep enough to stop it at that volume but my vote is- it is not.
Brad
Register to Reply 11 comments
Anonymous Poster (1); babybear (2); Beej50 (3); ducon (2); ndt-tom (1); sanjib (1); U V (1)
