Previous in Forum: Bentonite as Backfill Compound   Next in Forum: Where are Lobo & Evan methods of fired heater, furnace and Boiler design?
Hydrogen by Electrolysis
01/25/2009 3:49 PM
When producing hydrogen by electrolysis the electrode that let the hydrogen gas bubbles is the negative electrode or cathode. The metal used is nickel.
What is the metal used for the positive electrode where the oxygen will bubble from?
Good Answers: 243
Re: Hydrogen by Electrolysis
01/25/2009 6:27 PM
I would use platinum for both poles to avoid contamination from oxidation products. (actually attack of the anode by the oxygen...But Thats the way I am.
milo
01/25/2009 7:59 PM
I use Bubblenoium 243. It makes the extraction process seemless.
Good luck!
01/26/2009 1:26 AM
Hi..Stainless Steel is known to work well. Good plans available, try typing "smacks booster" into your search. Be carefull and employ all safety precautions in your build.
Good Answers: 74
01/26/2009 1:59 AM
kilomark
Years ago (20) I used platinum coated titanium manufactured by Degussa, Germany. It was worth the money. Go and have a look what they have on offer now a'days. Good luck, Ky.
The Twain Has Met
01/26/2009 5:43 AM
Anything that is conductive and that will not react with the electrolyte or oxygen would do the job.
There is a good page on electrolysis on Wikipedia.
01/27/2009 9:36 PM
Salt water chlorinators for swimming pools seem to be using Ti electrodes
United States - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
01/28/2009 5:11 PM
Nickel metal works very well for both electrodes in the electrolysis of water under alkaline conditions (i.e., using sodium hydroxide or potassium hydroxide as the electrolyte). Nickel catalyzes the reaction (especially the oxidation step), but it is fairly expensive, so this might be practical only on small scales. I hear that stainless steel works well, with slightly lower efficiency, but very affordable (again with hydroxide electrolyte). Platinum is probably much too expensive for your application.
Problems worthy of attack prove their worth by hitting back. -- Piet Hein
Register to Reply 7 comments
ky (1); lyn (1); Metman (1); Milo (1); PWSlack (1); sceptic (1); svengali (1)
