Previous in Forum: hydraulic scissor lift   Next in Forum: SEA
Water Pump
01/27/2009 1:05 PM
how to calculate water discharge of a pump having delivery pipe 8 inches dia and discharge pressure 150 psi
Good Answers: 97
Re: Water Pump
01/27/2009 5:15 PM
At least tell us the color of the pump.
Actually that wont help much more detail is needed.
Is this the pump for fire fighting?
You should ask the supplier / manufacturer for detail and for your own convenience a pump curve. When you have a curve ask another question with all the detail and CR4 will put you on the fast lane.
Re: Water Pump
01/28/2009 6:38 AM
you would need inlet outlet pressures, velocities, elevations, and friction loss. but that good ole' pump cuve is your starting point
Re: Water Pump
01/28/2009 8:46 AM
Install an orifice plate or venturi meter that is sized for you capacity everything else is just more technology to manage and cry over when it quits. If you need a digital reading them attach a differential pressure sensor to your manometer so that it can remain in a constant state of calibration check for the absolute lowest cost and absolute best "ease of use".
Good Answers: 97
Re: Water Pump
01/28/2009 2:24 PM
The discharge of a fire fighting nozzle at a specific pressure can be calculated or can actually be obtained from a lookup table or curve.
Contact your supplier.
Register to Reply 4 comments
You might be interested in: Water Pumps, Electrical Discharge Machines (EDM)
