Previous in Forum: FLUID MECHANICS   Next in Forum: Estimating science building central vacuum system costs
11 comments
TORQUE CALCULATIONS
02/01/2009 1:56 PM
WHEN WE ARE USING AN M10 STANDARD(METRIC THREAD)BOLT LENGTH 65MM . FOR THIS BOLT HOW WE CALCULATE THE TORQUE VALUE FOR TIGHTING THE BOLT IN THE 70MM FEMALE THREAD(METRIC THREAD) IS THERE ANY CALCULATION FOR TORQUE SETTING .
ANOTHER DOUBT IN THE TREADS WE ARE USING BSP,NPT, MM WHAT IS THE DIFFERENTS IN THEIR PITCH HOW TO FOUND THESE THREADS IS THERE ANY RULES IS THERE HOW TO CALCULATE PLS GIVE SOME TECHNICAL INFORMATION ABOUT THREAD CALCULATIONS
Re: TORQUE CALCULATIONS
02/01/2009 2:27 PM
No need to yell.
Charlie don't surf.
Good Answers: 103
02/01/2009 8:44 PM
Also check previous discussions - at least 3 threads are there
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
02/02/2009 8:48 AM
You have some other posts that are "yelling" as well, please take the advice on the first response and don't put everything in caps.
Money doesn't talk, it screams in your face.
02/02/2009 11:17 AM
Try a book like Machinery's Handbook or find a spec sheet to find torque required.
02/02/2009 11:32 AM
You just need to buy a manual or handbook what brings the differents standards of threadings, and all that simple workshop basis like the "Oberg-Jones" or the "Colvin-Stanley".-
02/02/2009 10:07 PM
From CMTI Machine tool design handbook we can find tighting torque
For M10 grade 6.6 Fasteners tighting torque is 1.4 kgf.m
02/02/2009 10:17 PM
Your "Engalish" .. in both your threads is as good as German to me.
02/03/2009 4:37 AM
Singh
It is always difficult to calculate torques required for particular industry as all have slightly different requirements and needs.
I find it best to make an excel sheet using data from the net or books and then modify the values to suit. Try a link like http://www.efunda.com/designstandards/screws/calc_bolt_torque.cfm
Torque requirements are affected by material, lubrication, surface finish and so on. I have never found one value for any screw or bolt to suit all. You need to modify the values to the particular industry or even company you are involved in.
02/03/2009 1:06 PM
Hay, I thought somebody may talk some thing 'bout the different type of threads which was the main topic of discussion.
But..... Poor me........I'm seeing u all r just yelling and pelling at each other.............
please come up naa......if any one knows the difference........please be silent if u don't know.......
IT IS VERY EASY WHEN I WANT TO. AND IT IS VERY DIFFICULT WHEN I WANT TO.
02/04/2009 3:47 AM
The different threads are for different purposes and have requirements to suit.
Try the Machinery's Handbook under screw thread systems. It has BSP, Whitworth and the rest. If necessary the supplier can get you the information required.
I am sure there is also information under specific threads on the net - the hand book is a good start.
Hope that helps
02/03/2009 1:28 PM
Thanks for your advise it"s very useful for me is there any other site avilable means let me know please. thank you
Register to Reply 11 comments
Anonymous Poster (3); betomachine (1); Davis (1); ddhanjal (2); ferquiza (1); kns (1); sb (1); stevem (1)
