Previous in Forum: Wireform Ring Clips   Next in Forum: Small Gas, LPG, or Diesel Turbine Generator
NPT Fittings for Hydrogen Pipe Lines
02/02/2009 5:39 AM
Can we use NPT fitting on the Hydrogen pipe lines?
-Nava
The best way to escape from a problem is to solve it ; The full use of today is the best preparation for tomorrow:
Re: NPT Fittings for Hydrogen Pipe Lines
02/02/2009 12:08 PM
  • Temperature?
  • Pressure in the line?
  • Flowrate?
  • Line size?
  • Materials of construction of the line?
  • Secondary containment?
  • Lagging material?
  • Sources of ignition nearby?
  • Indoors or outdoors?
  • What does the operating organisation's Piping Standard say on the subject?
02/03/2009 12:27 AM
good luck if you have to ask this !
keep some cotten towel hanging around where you are working at least then you will see the fire before the explosion .
02/03/2009 2:28 AM
Nooooooooooooooooooooo. Only may be used for small sizes flexible and armoured hoses.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
02/03/2009 4:06 PM
Instrumentation was the only thing I ever saw threaded in a hydrogen plant or pipeline.
Money doesn't talk, it screams in your face.
02/04/2009 12:50 PM
NO!
I don't care how carefully/tightly you assembly this. Pipe threads will leak hydrogen.
Abdel Halim Galala (1); betomachine (1); dadw5boys (1); PWSlack (1); silvCrow (1)
