Previous in Forum: RoHS   Next in Forum: Commercial Piping
India - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Valve
02/03/2009 4:17 AM
How Hydrotest is carried out for a valve?
Sanjay Vadhaiya I BecRel Engg. Pvt. Ltd. I Reliance Industries I Navi Mumbai-400701
Re: Valve
02/03/2009 7:31 AM
With a non-compressible fluid, as with a hydrotest on anything else. Water is a good fluid to choose.
Good Answers: 103
Re: Valve
02/03/2009 8:42 AM
Hydro: From Greek Hydra - means water A prefix added to the start of a word. Indicates that "water" modifies the word. Created to expand meanings. Can be used with many words to form new words.
Test : To examine or Try - (one of the meanings)
To put to the prrof; to prove the truth, genuineness
Hence in hydrotest - you prove the genuineness of the valve using water.
But you mean Hydrostatic Pressure test of the valve
for that you please find the
a) Type and condition of service
b) The applicable codes.
Since you are from petrochems, I feel that API will be applicable to you. Go through API standards for valves, (eg API6D, also a few others are there or you may have to go for ASME if that is your application)
The details of Hydrostatc tests as well as other tests are spelt out in these standards.
Register to Reply 2 comments
