Previous in Forum: robot with muscles   Next in Forum: Temperature and Electricity in AC Systems
presentation on usage of exhaust heat
02/05/2009 10:39 PM
can anyone help me by providing some information regarding usage of exhaust heat to run automobile air conditioner
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: presentation on usage of exhaust heat
02/06/2009 9:48 AM
I've never heard of this, but it doesn't sound like a bad idea at all.
What idea's do you have? If you could come up with a plan, and a realistic proposal, you could generate much interest.
Put in some effort. Then get back to us.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 19
02/06/2009 2:45 PM
I agree with brick. You could be into something. We put the exhaust heat into Chillers(gas-fired) to generate air conditioning but your idea can be worked on. Register yourself first so we know its you rather than being confused as there are too many guest contributing.
Good Answers: 247
02/07/2009 12:03 AM
You can peruse this CR4 thread. A search through CR4 should turn up another thread or two, I think.
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
02/07/2009 12:53 AM
Brick is always on track. A great app would be a large tryck traveling long distance with a cold box behind it.
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
02/07/2009 8:16 PM
Brainstorm challenge !
Maybe use surplus heat from exhaust system to run closed circuit "steam" (or other gas) turbine generator. Turbine goes around and around and the generator cranks out electricity, charging a large capacity battery system. Do what you will with the batteries and extra electricity.
Happy Trails !
02/08/2009 11:37 AM
the heat may be used to power a small adsorbtion system. I'm not an expert with these systems but the do need a heat source to run the cycle. Don't think they can operate while bouncing around in an engine compartment but maybee its possible!
02/09/2009 11:38 AM
The operation of absorbtion refrigeration systems work quite well running down the road. Anyone with a propane fridge in their RV can attest to that. Generally they should be kept fairly level, but the sloshing action of a vehicle in motion keeps the ammonia mixture sufficiently in the concentric ring heating area used in most systems.
Blink (1); Brave Sir Robin (1); Bricktop (1); ckartson (1); ducon (1); Happy Fish (1); miketheboilerguy (1)
