Previous in Forum: Clearing startup items in "msconfig"   Next in Forum: Accessibility options
16 comments
United Kingdom - Member - British
Restricting Websites
02/07/2009 9:38 AM
Hi,
Is it possible to create a list of restricted websites, that doesn't involve a program which is installed onto the user. I am admin, and have access to the linksys wireless router. The site for the router is: Wireless-G ADSL Home Gateway
Thanks,
bondy111
Good Answers: 62
Re: Restricting Websites
02/07/2009 11:12 AM
Since you reference linksys are we talking about a home network here? The answer depends on environment.
02/07/2009 2:10 PM
Yes, home network
bondy111
Good Answers: 62
02/07/2009 2:27 PM
Wellllll...given your equipment you could use a proxy service and lock all your outbound inbound traffic through it - but there is bound to be a fee
I've got a lot of not answer
except you might try here
02/07/2009 11:11 PM
It's certainly possible to block IP ranges at the router level but you might want to consider using the OS to do this.
If you're using Windows this file already exists, it's called a 'hosts' file and you can freely add/edit it with any text editor e.g. notepad. For more info :
http://en.wikipedia.org/wiki/Hosts_file
http://www.mvps.org/winhelp2002/hosts.htm
Charlie don't surf.
02/08/2009 1:52 AM
So you just add them to the file?
bondy111
Good Answers: 97
02/08/2009 4:05 PM
Hello Bondy111,
Go to start / control panel / internet options / Security / Restricted sites and add sites you want to restrict access to the blocked category.
02/09/2009 1:47 AM
Thanks,
Would you have to do these changes for each internet browser, and would they apply right across the system?
Also, I was hoping there would be a more techical way, through notepad, making a DOS program, so it would be harder to be located.
bondy111
02/09/2009 1:49 AM
BTW scrap the "that doesn't involve a program which is installed onto the user", I think my mind may have wondered. It needs to be installed on my user, but apply changes right across the system.
bondy111
02/09/2009 8:37 AM
As stevem suggested, the "hosts" text file is your best bet if you want to control access on a single machine. I would suggest doing this. Using Internet Options only applies to Internet Explorer, so other web browsers will not be restricted.
Using the router to restrict access is an ideal solution for an entire network, and is difficult to disable, as the router is password protected. However, this can be reset by hard-resetting the router (pressing the reset button on the back of the hardware).
Maybe a combination of both is your best bet if you do not want to use additional firewall software.
Good Answers: 97
02/09/2009 12:29 PM
Instead of over complicating the issue just don't allow the turkey to use your stuff
02/09/2009 10:08 AM
Of course, there is an easy way to see restricted content by the user - simply look for the cashed google page.
02/10/2009 11:27 AM
Guys i'm pretty sure you can do this right on the router config page (default ip: 192.168.1.1).
I remember there being a tab which gives you control over blocking websites and or applications. I would check that out before installing software or something else which would take more steps.
Good Answers: 119
02/13/2009 1:17 PM
Try using Zonealarm firewall with a linksys router. It semi-integrates and provides broader control and protection than the hardware firewall alone.
My linksys router (almost 2 years old) supports this functionality. I don't know if newer versions do as I haven't kept up with the newer linksys products.
Hooker
Good Answers: 97
02/15/2009 6:18 PM
Zone-alarm firewall will perform this function itself by using the malicious site blocking tool; if you don't want it block it.
Good Answers: 97
02/15/2009 10:14 PM
Yes, this can be accomplished within the linksys setup software. Also you may designate when and for how long specific computers can access the web.
Hobbies - Musician - Tube Amps Only Please!
11/03/2009 4:13 AM
Some software allow this I would Google.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Register to Reply 16 comments
Anonymous Poster (1); Bondy111 (4); bwire (4); coonj (1); edignan (2); Hooker (1); maveric_manic (1); rimig88 (1); stevem (1)
