Is it require the unspliced equipment bonding jumper from 6.6kv NGR (Neutral grounding resistor) to switchgear, if NGR and switchgear both already grounded with same grounding mesh of 120sqmm conductor. In this regard NEC article 250.36 shows for high impedance grounded neutral system of 480 to 1000 volts shows NGR and swichgear connected with unspliced equipment bonding jumper.
