Previous in Forum: Lunar Landing   Next in Forum: A little food for thought.
Automatic Screw Feeders
02/12/2009 10:25 PM
Hi all,
Is there any method to automate screw feeding.
The screw is slotted screw and the major problem is that the L/D Ratio = 1. hence it is not possible to feed it by tubes.
Regards,
Praywin
Hobbies - Car Customizing - Dances with Trees Canada - Member - because I can Hobbies - CNC - too much fun Hobbies - Target Shooting - paper shreader
Re: Automatic screw feeding
02/12/2009 11:59 PM
belt feed. similar to this process.
Kevin "Dances with Trees" Willey
02/13/2009 12:29 AM
Thanks for your reply.
But what is belt feed can u show me some images
02/13/2009 11:45 AM
have you done a search of gobalspec.com they should be a listing for manufactures there.
Re: Automatic Screw Feeders
02/13/2009 11:34 AM
Contact your local nail rep. from a reputable company like Bostic or RV Evans.
David Cummings at RV Evans (in ST Louis, MO) would be who I would call. 800-489-1107
they have bulk nailing systems that use shakers, and magnets to feed. they could probably come closest to having a answer than anyone would.
Good luck,
Shane Poindexter
Carthage Specialty Pallet
02/17/2009 9:14 AM
Try an internet search under "bowl feeders" or "vibratory bowl feeders" or "pick and place systems".
Basically, the screws would be bulk fed into a hopper, which feeds controlled amounts by shaking through an in line weigh station, into a vibratory bowl. The bowl sits on a series of springs, which, when vibrated through electrical coils, causes a rotational lift and drop action which propels any small items in the bowl in the direction of the vibration.
Movement of the parts is now fully directed and controlled by the skill of the bowl tooler, who creates a path around the inside outer wall of the bowl, usually a continuous spiral step, with any number of ramps and knock off devices to deflect parts that are not properly oriented. The parts, climb the inside wall, creating a line-up of oriented parts at the top, ready for assembly.
A good bowl tooler should overcome the 1D x 1L issue you describe.
Regards
Jim...
Dances with Trees (2); hpraywin (1); jimmymac28 (1); pallets (1)
You might be interested in: Stock and Strip Feeders, Solids Feeders, Parts Feeders
