Previous in Forum: Thermostat + Co2 Sensor in single device tied to BMS   Next in Forum: How good is LED lighting for use in growing food plants.
what is the best suitable pipe for HCL40%
02/13/2009 11:50 PM
Hi
In last massage i wrote 60% but i would be 40%
Pressure:2 bar
temp:below 50
Thanks
Re: what is the best suitable pipe for HCL40%
02/15/2009 12:56 AM
don't use SS
Good Answers: 101
02/15/2009 8:42 AM
Sch80 PVC will work well for this.
02/16/2009 5:58 AM
Agree. PVC unlikely to be affected by HCL.
HDPE should also work well and can be easily heat welded.
02/18/2009 9:09 AM
CPVC would be a better choice than PVC. If outdoors either use CPVC or paint your PVC pipe to prevent UV degradation.
Teflon llined steel pipe is typically used for HCl service
DVader1000 (1); healybj8 (1); Mikerho (1); sceptic (1)
