A search for off-the-shelf speed regulators failed to turn up a unit suitable for this application which consists of a pretty strong DC motor mated to a right angle worm drive with an internal gear reduction of about 35:1 . Lots of nice equipment out there but everything was for 90 VDC and up.
This motor only requires 24VDC. I would enjoy a factory built unit with torque compensation, soft start and soft landing on shutdown so as to prevent inertial loads on the fixtures attaced to the turntable.
The final drive will have additional external reduction via cogged or V belt pulleys to provide a final drive ratio in the vicinity of 60 to 1.
The 16" turntable will be driven between 2 and 45 RPM with most of it's use in the 25 RPM range.
I'd like a frequency driven speed control and would like NOT to have to build and solder circuit boards. I know how. I simply don't have the time.
Can someone suggest a manufacturer of a speed control that will solve this for me?
Thanks
L.J.
