I have two questions for you about the design calculation of LPG spherical tank..
1. Which standard that should i applied for this kind of internal
pressure? (ASME 8 div 1 or 2). I have read about the internal pressure
limit of div 1, which is 3000 psi. But The existing project (has the
same internal pressure with mine) is refer to ASME 8 div 2. Then which
one should i take?
2. In nozzle calculation, are there any differences between the
formula in calculating nozzle thickness in spherical tank and in
cylindrical tank?
Thank you very much for your kind attention. Your prompt reply is really expected..
