Hi all, i have been working on a pump perfomance investigative project. Through close obsrevation from the calculations that i have done, it is apparent that the pump actually needs less than 45 kW of power to run. The calculations also prove that a 132kW motor that is currently installed is not suitable for the application; instead a 45kW motor should have been used.
first question: Is it advisable for me to conclude that 87kW is being thrown away everytime a 132 kW is in operation instead of a 45kW?
Second question: Since this is a 132 kW motor, does that mean the motor draws the equivalent amount of energy from the source when it has to run even if the very same motor is producing less amount of output power?
